Turn Steering Wheel Car Stalls.... Axle issue too
Old Mar 19, 2010 | 08:51 PM
Rood's Avatar
First Question.
Okay so I was doing some engine cleaning about a week ago and pulled the UIM off and cleaned the TB and make a new EGR block off plate because the cars idle was bad (sounded like a miss). Put it back together and idle is fine, drives fine. Nice.
Starting yesterday when the car is at idle (5spd) and I turn the steering wheel, the cars idle drops and the car stalls. Feels like the wheel gets stiffer and its harder to turn.. When I have it at a rev, it turns okay, no issues. I dont want to blow a ECU.
I am not throwing any codes. Could this be the IACV?
Second Question.
I need a new axle. The boot is ripped, my car is slammed, whatever. But, I only hear a clicking noise when in gear and moving. Does this sound right? When I am coasting and the clutch is in there is no sound.
Old Mar 19, 2010 | 10:13 PM
zero2sixtyZ's Avatar
You embarrass me.
Diff?
Old Mar 20, 2010 | 12:05 AM
QNO_A32's Avatar
Originally Posted by mrood1986
First Question.
Second Question.
you answered your own question...
Old Mar 20, 2010 | 07:32 AM
Rood's Avatar
I just didnt know if it could be another issue regarding the fact that it only clicks when in gear and moving... Wasent sure if somebody knew or not.
Now about the idle issue regarding when turning the steering wheel, and not moving. The engines rpm drops super low and then stalls unless I give it gas.
Is this for sure the IACV? Then cleaning it would only be a band-aid? And it would be best to replace it and then go to the dealership for an idle relearn?
Old Mar 20, 2010 | 05:50 PM
Rood's Avatar
any ideas for my idle situation?
Old Mar 21, 2010 | 12:54 PM
mandyfig's Avatar
Power steering problem? PS pump?
Old Mar 21, 2010 | 04:15 PM
Rood's Avatar
Is this the sign of it going out? Because the idle just drops quick unless im revving or moving. Otherwise it dies.
Old Mar 21, 2010 | 04:33 PM
mandyfig's Avatar
I am still not sure why the car would die while you steer...Perhaps the pump is seizing? Adding a lot of load and therefore dropping the rpm, affecting the alternator?
Get somebody to steer while you look at the alternator and see what it does.
Old Mar 22, 2010 | 06:12 AM
Rood's Avatar
steering wheel is not difficult to turn, when moving its fine or when the idle is up.
Any other ideas?
Old Mar 22, 2010 | 02:42 PM
mandyfig's Avatar
The test for power steering is when the car is stopped. Turn wheels left to right, do you lose rpm?
Old Mar 22, 2010 | 03:11 PM
Rood's Avatar
Yes, it's any direction from any point
Old Mar 23, 2010 | 09:40 AM
mandyfig's Avatar
I have to do this on my car and see what kind of results I get, then I will post. I suspect your power steering pump is the issue, just speculation based on logic, but I have no experience on this. It appears that the pump is binding and is putting a huge load on the drive belt, enough to lower the rpm (increased load on engine).
Old Mar 23, 2010 | 11:16 PM
BronxSleeperMax187's Avatar
Check your power steering pressure switch or troubleshoot the engine idle control operation....
MikesChevelle
Nov 23, 2024 11:17 AM
trasmadean
Feb 1, 2017 08:20 PM
Flores94
Aug 13, 2015 01:17 PM
Flores94
Aug 11, 2015 12:53 PM
MikesChevelle
Aug 6, 2015 11:36 AM
