Improved 0-60 Time after NWP Spacers and Spark Plug Change
Well,
2 days ago I installed my NWP Intake Spacers and new Laser Platinum Spark Plugs. I reset my ECU after install and have been enjoying the results ever since. I guess I'd better mention the timing advance too... I had it advanced to 17 degrees BTDC.
So, tonight I was driving around and decided to get a rough idea of my 0-60 time. I say 'rough idea' because even though I had a stopwatch, the roads were a bit wet and I have winter tires on at the moment. So after about 3 runs I have concluded the following: I have gained at LEAST ONE FULL SECOND on my 0-60 time!!! Even with horrible spinning launches due to semi-wet roads and winter tires, my 02 Max SE Auto was running UNDER 7 seconds 0-60. This is a full second better than what she used to do without spacers and new plugs on dry roads with better tires!!! I can't wait 'til I put my new summer tires on in a couple of weeks and I can test out my car on dry roads.
The NWP spacers are definitely worth every penny. As soon as 3900 RPM hits and the VIAS valve opens, my car just TAKES OFF!! You can actually feel the added power right there and up (almost like having a really small turbo hehehe) My IM doesn't get heat soaked now, and as a result, there is no performance decrease even after having driven the car for hours. I swear I can feel added torque and power across the entire power band (even down low) but it is definitely apparent at 3900+ RPM. Even though I've been feeling this for a few days, I was shocked tonight to find that spacers, new plugs, and a timing advance had taken 1+ seconds off my 0-60 time. It's great!
hey, what is the best y-pipe I can get without dropping $800 on Cattman headers/y-pipe. Are there any other options?
Exactly that, unless you catch him having a sale. Worth every penny, too.
OP, I'm happy to hear how ecstatic you are about the change. However, I'm guessing your old plugs were pretty bad. The spacers are certainly awesome, but not 1.0 second awesome. Let's not get carried away here and create unrealistic expectations.
Realism aside, I was similarly enthusiastic about the spacers when I had them installed. Half a year later, no leaks, no problems, just a nice little boost that I still appreciate. Enjoy, man.
nice.. good to see people are happy with the spacers. i just ordered mine too, so they should be here in a few days. 225 + 10 for shipping. i also ordered some headers and grounding kit as well. so i can't wait to see what the results are after that!
Good to hear, but stock in good running condition you should be 6.2-6.5 ish in the auto. Was just watching a video on youtube where one guy got his 0-60 down to 6.3 sec with his 02 stock auto after a few runs.
To the OP, have you done the GAB mod? If not, then maybe that explains why my GAB'd '02 auto does 0-60 in 6.5, but you needed the spacers, timing advance, and new plugs to get under 7. Another thing, did you leave it in drive, or manually shift it? Shifting at redline speeds things up a bit. My 6.5 sec 0-60
EDIT: You have done the GAB mod...
More:
http://www.nwpengineering.com/VQ30DE...ifications.pdf
To OP: Good job w/ your 0-60 time trimming
Originally Posted by Z-Powered;7482451Another thing, did you leave it in drive, or manually shift it? Shifting at redline speeds things up a bit. [URL="http://www.youtube.com/watch?v=C33p4bfR-ZI"
My 6.5 sec 0-60[/URL]
Yes.
Yeah, I got spacers cuz they are supposed to be the overall best/show the best performance gains... I might do the block plate now, but I'm worried about losing low end... I've gained a bunch of noticeable low-end torque with the spacers and I'm worried about losing any of it.
Speaking of spark plugs, I bought my wife a 2000 SE last week with 135,400 kilometres on it (84k miles). The stealership where I bought it said the plugs don't have to be changed until 167,000 kilometres (104k miles).
Is this achievable?
Typically 4th Gen plugs are changed at 60k miles. I changed mine at 67k miles and they were on their way out. The 4th Gen plugs must be different than the 5th Gen plugs.
I replaced my 4th Gen plugs with OEM laser platinum plugs and plan on replacing the 5th Gen's plugs with OEM plugs as well.
Is this achievable?
That's the new bull**** Nissan is pushing through to the salesman and they use it as a sales pitch.
Honestly I change the spark plugs on a car when I first buy it, and change them about every 40-60k miles
MaximaDrvr
Aug 19, 2015 08:20 PM
