Saggy Door Fix
Saggy Door Fix
I did not find any threads on this besides buying new hinges and watching it happen again.
These hinges are just stupid. You can tell how it wears.
I am cheap so I went to home depot and got a pack of metal washers and loosened the bolts on the bottom hinge to door and slid two of them behind there and tightened it down. The results are a door that closes just fine and looks good as well. If it sags after the washers on my car after some time I will buy a new hinge and wait till it sags and then do the washers again. Hopefully there wont be a need for that.
What size washers did you use?
This might help http://forums.maxima.org/7507022-post64.html
I'm off to pick up some metal washers and if I can, I'll throw them on in the parking lot.
Last year I bought a 2000 maxima and took it for state inspection. It failed because of the door hinges. They wanted me to get it repaired so I went home and unbolted the door hinges slipped 2 thick washers in the lower hinge and bolted it back. Prob. solved took it back and it passed inspection without any prob. It worked so beautifully that I even forgot that my hing is wearing off until I read this thread. It is still working and no one can tell that there is any sag in the door. But if you grab the door and lift it up and down, then it moves and then you can tell that it is not solid and that there is something wrong with the hinges. but I dont ever do that so it doesnt bother me. So, yea its the best and the cheapest fix I have ever seen.
I am so glad that I know about this site. Now, tomorrow I am replacing my steering wheel pressure hose(another MAJOR and expensive prob with all the maximas). We'll see how it goes. So, all of you guys be ready because yours will leak one day too. It will happen to every maxima out there. Its just a matter of time. My maxima has 160K + miles.
How much were all your doors sagging? I tried washers that looked exactly the same installed (as picture in other thread) but that just made my door bump on the latch like it was too high. So i got the joy of removing them too. I just hope when i install thinner washers, the doors wont sag even more and need the thicker ones.
And my door jams are nasty. Like someone just took a spraycan of grease and shot the entire area for me to clean up. So what shoulda been a clean job was very different. Sometimes i wanna take the previous owners and
Where's John's spoonfeeding jpeg?
The spoonfeeding baby is in my image gallery... go play.However, good to know this simple trick. Better a 50 cent washer than an hour's labor at the dealership.
