y-pipe questions
Old Apr 6, 2010 | 11:24 PM
rayac88's Avatar
y-pipe questions
i have been searching for hours to find how easy the installation on a warpspeed y-pipe is on a 2000. I would buy it off ebay but i do not want to move any o2 sensors or cut existing pipe.
how much do they usually go for? or should i have one custom made y-pipe made from a local muffler shop?
i'm in Florida no emission testing
Old Apr 6, 2010 | 11:37 PM
J2FRESH's Avatar
have you try'd checking there website: warpspeedperformance.com
Old Apr 7, 2010 | 07:18 AM
merovi's Avatar
On paper the install is easy. When actually attempting you will need professional tools. Since you are in Florida you may have an easier time with less rust though.
When I replaced my y-pipe for the first time we had to cut out all 6 bolts holding the stock Y to the headers/cats, and the bolts at the main cat. That required a torch to cut it all out. Once the stock pipe is out its as easy as just lining everything up. make sure that your exhaust is sitting straight as well. My warpspeed was not a perfect fit and required heating up and bending numerous hanger through the rest of the cat back to get everything sitting straight and flush after install.
Old Apr 7, 2010 | 08:50 AM
NissanTun3r's Avatar
I managed to get my old y pipe off the car easy enough, but the warpspeed is not a bolt on. It required some moderate fab work including moving an o2 bung, and cutting some pipe and welding...
Old Apr 7, 2010 | 10:55 AM
e-subliminal-2's Avatar
It's not hard at all dude.. No write up is honestly needed if you know what you're looking at. The only concern i've ever ran into was rust. So be careful. I believe all you need is a deep 14mm socket. spray some wd40 on there before, or pb blaster. Shouldn't be hard at all. If everything goes well it took me 20 minutes.
gl.
Old Apr 7, 2010 | 07:09 PM
CMax03's Avatar
IIRC you will not have to relocate the rear O2 sensor it's a straight install!
Old Apr 7, 2010 | 08:04 PM
i had to relocate the 02 bung that is next to the flange that connects to the front e many
Old Apr 7, 2010 | 09:37 PM
rayac88's Avatar
well i ordered it. after trauma from the intake spacers im not sure if i wanna deal with any misfits. i may take it to an exhaust shop and pay like 50 bucks to put it on.
i will be putting it on with the stock exhaust so do i need a coupler that fits down to 2"?
Old Apr 8, 2010 | 06:14 AM
merovi's Avatar
Depends if you ordered the right pipe for your car. I had a Cali spec and bought a cali spec pipe. I did not need any extra coupler or pipe and I did not have to move any sensors.
Old Apr 8, 2010 | 10:47 AM
J2FRESH's Avatar
Old Apr 11, 2010 | 06:54 PM
mysticalpun's Avatar
Does anyone Know if the Cattman Y Pipe being installed would take away a the P0420 code on my car, I have a 01 AE Max and i'm not sure if that will take away my problem. Can someone let me know?
Old Apr 11, 2010 | 09:29 PM
Rods03Max619's Avatar
Yeah they go for 250 with like 6-7 hp gain I think.
Old Apr 11, 2010 | 11:53 PM
rayac88's Avatar
didn't know they had one but i checked it and ordered one. they go for 200 spoke to them through ebay so im just waiting on the part to ship
Old Apr 12, 2010 | 07:05 AM
merovi's Avatar
Installing a y-pipe is more likely to throw a code the remove one. Maybe look into an O2 sim?
Old Apr 12, 2010 | 06:33 PM
Stagnet04's Avatar
subscribing because Im in the same boat, just got an 01 SE and searched for Y-pipe installation and theres a bunch of different answers and opinions on weather or not youre going to need to extend the O2 sensor. The warpspeed website doesnt address this issue either....
Old Apr 12, 2010 | 06:34 PM
Stagnet04's Avatar
BTW, where did you get a cali spec y-pipe from?
Old Apr 13, 2010 | 12:12 AM
McSteve's Avatar
my stillen one is cali spec. didn't need any modification what so ever and fit on perfectly. I installed it myself on jack stands. It's for sale too.... =D
Old Apr 13, 2010 | 06:56 AM
merovi's Avatar
I had gotten a stainless from the FS section of the site years ago. Just keep your eyes open and check often. They go quick.
Old May 17, 2010 | 10:01 PM
rayac88's Avatar
just so you know if you order the right one there is no moving the o2. installer did it in 20 minutes with a lift pre pb-blasted nuts and air tools i personally tried to get it off with a socket set but it was hell so i just gave $100 to the guy to do it the installer didn't have to move the o2 sensor. the gains are great up top but you need something to help built more torque. i get more torque steer when i hit over 4k on an auto
Quickywd01
Sep 21, 2016 09:36 PM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Socalstillen
Sep 26, 2015 12:01 PM
