Lots of brake dust on one side
Old Apr 7, 2010 | 08:36 AM
shook187's Avatar
Is it normal to have only the drive side wheel to get most of the brake dust? I'm getting lots of dust on the driver side and almost none on the passenger side.
Old Apr 7, 2010 | 08:43 AM
ajm8127's Avatar
Check your pads to see if they are wearing evenly from side to side.
Old Apr 7, 2010 | 08:46 AM
ImmaSquashYou's Avatar
yup, thast what i would do. If the pads on the driver side are less than the passenger side, your caliper is prob starting to seize or you need to re-grease then return bolt that moves.
Old Apr 7, 2010 | 09:06 AM
shook187's Avatar
I'll take a look.
Sucks casue I just got my brakes done.
Old Apr 7, 2010 | 09:11 AM
Feldman's Avatar
+1
you are unfortunately probably going to have to replace your caliper (i would do both). you an keep your old rotors and pads though so it's not a total loss
Old Apr 7, 2010 | 11:49 AM
shook187's Avatar
Originally Posted by Feldman
+1
I'm pricing calipers now!!! They go for big bucks
Old Apr 7, 2010 | 12:09 PM
Matt93SE's Avatar
STFU n00b!
they're $50-60 at the local parts store.
before you start freaking out about it, pull the wheels off and actually look at the car.
Is it pulling to one side when you brake?
Old Apr 7, 2010 | 05:07 PM
Fasteddie01's Avatar
When you say 'just got my brakes done' do you mean you did them, or you had them done. If some shop, they should have caught the prob. I'd go after them to maybe get cut rate on labour at least.
Old Apr 7, 2010 | 05:31 PM
tonyinfiniti's Avatar
same thing happened to me after I tried to justify being cheap on front pads and rotors. pass. side smooth, and driver side etched, and tons of brake dust... BTW my calipers were perfectly fine, just got what I paid for.
Old Apr 7, 2010 | 06:13 PM
bigtimer's Avatar
hey,im new on here but my pads are good and they sound like there grindind and lots of brake dust,but i,ve got bigger problems wit my car that i have to get fixed first
Old Apr 7, 2010 | 09:51 PM
maxx0831's Avatar
I had the same thing happened to me abt 2 weeks ago, found out it was one of the sliding pins that seized
Old Apr 7, 2010 | 10:20 PM
4thGeN's Avatar
"I'll take a look.
Sucks casue I just got my brakes done."
Gotta completely bleed and change brake fluid, re-surface rotors, and grease the pins. U probably got some goop stuck in ur break lines OR like u said u went and had urs done :/. never trust a under trained "tech" work on breaks. i do all my ownt work, but try to do wht i said and u will have a whole new ride with ur breaks and check ur master!
Old Apr 8, 2010 | 12:39 AM
shook187's Avatar
I'm hoping thats the problem. Anyways I'm having the car checked out today.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
