Installed turbo timer and can't find VSS signal...
I figured I would get more responses in here. I just installed a Greddy Auto Turbo Timer and cannot find a VSS signal due to the fact that my A33B does not have a VSS (manual). Greddy is telling me I am pretty much SOL with that feature of the device. The turbo timer still works if I set a time for it to run after ignition is turned off, but I would like the Auto function to be enabled (hence the fact that I purchased this particular model) and it won't with a speed signal.
Is there another SAFE place to get the VSS signal?
vss wire is behind the cluster behind the speedometer. I forgot the color but if you search in the audio forum they will have the answer there because a lot of Navigation units need the VSS wire. Good luck
Wire 68 on the ECU plug is the speed signal.
at 6mph its 2.5 v
at 19 mph its 2.0 v
page EC-148
im a 6spd too and i have this wire, its to tell the ECU how fast the car is going for cruise functions and i think speed limiter.
at 6mph its 2.5 v
at 19 mph its 2.0 v
page EC-148
max_speed97
Aug 26, 2015 07:46 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
