18x10 wheels
Old Apr 8, 2010 | 02:01 PM
03maxima1's Avatar
18x10 wheels
Anyone put an 18x10 wheels on a 5th gen maxima for the back wheels?
Old Apr 8, 2010 | 02:38 PM
Redline Maxima's Avatar
i think there was someone that did 19x10 in the back. i think it was indescentmax but i am not sure
Old Apr 8, 2010 | 03:24 PM
kzoosho's Avatar
Im running 9.5's rear + 20 offset. 265/40/18's
Old Apr 8, 2010 | 06:30 PM
MrDicks95SE's Avatar
Offset Is Everything.
whats your offset and tire size? i ran 19x10s on a 4th gen.
Old Apr 15, 2010 | 05:39 PM
03maxima1's Avatar
18x9 33 offset front
18x10 39 offset back
droped on h-techs.....1.6front 1.0back
Just came back from a shop and the guy said the rim is right against the spring and will not fit!
Old Apr 15, 2010 | 06:14 PM
NismoVQdet?'s Avatar
It will fit I ran the same size +35 though 245/45/18
Old Apr 15, 2010 | 06:49 PM
Fast1one's Avatar
That's why you run coilovers.
Get a spacer.
Old Apr 16, 2010 | 07:51 AM
03maxima1's Avatar
How did you do it if they are right up against your springs?
Is your car a 5th gen?
any help would be great i spent alot of money on these wheels and am screwed if they dont fit.
Old Apr 16, 2010 | 06:36 PM
phatboislim's Avatar
you'll be fine! i'm running a 19x9 with a +30 w/ a 265/30 on the rear..only reason i'm rubbing is because of the i-beam not being centered...and i'm dropped 2" all the way around
Old Apr 18, 2010 | 03:58 PM
Majestic Ken's Avatar
i got some but they arent here yet. go check out essential1's I30 same car pretty much
Old Apr 20, 2010 | 08:41 AM
03maxima1's Avatar
it seems i need spacers for the front and back is what im being told by the shop where my wheels are.
Old Apr 20, 2010 | 11:05 PM
Fast1one's Avatar
That can't be right, especially the front. Considering I was running 18x9.5 +35 in the front of a fourth gen for a while (with stock diameter springs and coilovers too), which has LESS clearance in the front compared to your 9j +33. Take them somewhere else.
The rear I would have to double check. Or just go out and measure. Make them physically show you the interference.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
