Mysterious not starting problem
Old Apr 20, 2010 | 04:32 PM
thedwyer00's Avatar
I was having many issues with the engine including running very rich. I replaced the injectors and adjusted the TPS and IACV. She purred like a charm. When I took it out for a test drive, it was being thrown into limp mode and would not let it reach over 2.8K rpms. I was informed that a common cause, especially since running so rich, was the EGR temp sensor not being able to register a difference in temp. I then proceeded to remove and clean the EGR, which was pretty nasty. Boil tested the sensor and it works fine. Reassembled everything and now I can not get it to start. Will turn and turn and turn but won't even sputter like it's trying. ECU is not throwing any codes. Getting fuel to the rail. Brand new fuel injectors, coil packs and spark plugs. Any ideas or advice will be greatly appreciated.
Old Apr 20, 2010 | 04:42 PM
mista0406's Avatar
i see you changed everthing but the fuel filter, have you checked that??? was it giving you problems ever starting before???
Old Apr 20, 2010 | 05:02 PM
thedwyer00's Avatar
UPDATE
Located starting problem which happened to be the start sig fuse (yeah I know noob mistake) Now that it is going I am having trouble hitting over 2.5K rpms. Engine will bog down.
Old Apr 20, 2010 | 05:04 PM
thedwyer00's Avatar
Throwing code 12- MAF, and code A1? Anyone know what code A1 is?
Old Apr 20, 2010 | 05:47 PM
thedwyer00's Avatar
So as things would have it, the minute I ask for help, the trouble is located. Someone prior to me had spliced in a new MAF sensor wire and used speaker wire so it was brittle and had snapped. The heat shrink was holding it together making it jump. Re-spliced and runs like a champ.
Old Apr 20, 2010 | 05:50 PM
Korath's Avatar
Nice job on locating the issue. I think I have to clean my EGR as well.
Old Apr 20, 2010 | 05:51 PM
95maxse3000's Avatar
i was gonna say maf
Old Apr 20, 2010 | 10:53 PM
thedwyer00's Avatar
Well it pissed me off seeing as I had to pay $700 a month ago when I was out in NE for some army training and dude said it was the MAF and replaced it. It was new too.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
