Need AC Accumulator/Drier Part #
Old May 20, 2010 | 09:32 AM
addicted2pain's Avatar
It is recommended any time you open your AC system to atmosphere that you replace the Accumulator/Drier. It is a small cannister that is mounted on a pad next to the AC Condenser on our 6th gen's. It contains desiccant that absorbs moisture from the system that would otherwise damage your compressor and corrode other components. Courtesyparts.com and the local dealerships only list a part number for the assembly with the condenser which is several hundred dollars and quite frankly ridiculous. That's like buying and engine block to get the oil filter.
I have purchased two aftermarket ones from Advanced Auto Parts and O'Reilly's (part# 83132) that both didn't fit. The holes in the canister for the freon lines are ~2mm too far apart. Autozone's model is special order and from the pic appears to be the same as the other two, just in a different box.
Any know the part number for the Accumulator/Drier from Nissan?
Old May 20, 2010 | 11:59 AM
oldngivout's Avatar
Willing to learn
The AC system design was changed for the A34 model. The liquid tank is indeed a part of the condenser, not serviceable separately.
Those 83132 models you have tried are the aftermarket failed attempt at giving you a generic part to replace a specific one. They often do that when there is in fact no replacement available.
Old May 20, 2010 | 12:07 PM
You mean they're treated as one part or are really one part? My drier is actually bolted to a pad with two tubes going to the condenser. Not doubting you...just confused.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
