2003 g35 sedan MAF works?
Old May 20, 2010 | 11:44 PM
asma123's Avatar
So I've been annoyed with my maf a little delayed so I figured since I have a g35 sedan in the shop right now while it's being worked on I can take the MAF and put it in my 5.5gen maxima and perhaps narrow down my problem if it's the TB or the maf. Any thoughts would be great. Thanks.
Old May 21, 2010 | 12:03 AM
a33i30's Avatar
I don't think it'll work, tell us how it goes if you try it out.
Old May 21, 2010 | 06:06 AM
NmexMAX's Avatar
dot dot dot ...
If it is an early model 03, it just might. Let us know.
Old May 21, 2010 | 09:49 AM
essential1's Avatar
My axles cry for mercy...
I was thinking the same thing^ Early model 03 G35s share the same ECU (pinout at least) as our 02-03 maximas.
Old May 21, 2010 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
Does anyone have any specifics re: mfg date when the 03 G35's turned to the latter ECU style (Z33/A34, etc)?
Old May 21, 2010 | 10:13 AM
essential1's Avatar
I saw it somewhere on G35driver a while back. I cant remember exactly though but i'll look.
Old May 21, 2010 | 10:36 AM
essential1's Avatar
Ok, havent found the exact build dates, but I did find that if the ECU harness has a GREY colored connector, it is the early ECU. If it has a BLACK connector, it's the later ECU.
Old May 21, 2010 | 07:16 PM
asma123's Avatar
I'm scared of frying my ecu. I don't know if I should try but I will check the pin connector on it to see if they are grey or black.
Old May 22, 2010 | 12:20 AM
AnDyMaN's Avatar
i have a maf from a g35 sedan, but its a am600. if you look on car-parts.com and look fr mafs, it will show early model g's.
95Maxi
Aug 29, 2015 09:38 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
kenc15
Aug 5, 2015 08:29 AM
