No 12v Power to Radio.
Hey
Hope someone can help...
On my Radio Harness I have a Pink/Blue wire that supplies 12v from the battery and a blue wire which is the switched 12v (IGN). Now if I measure the voltage without the radio plugged in (checking from harness) I can measure the 12v switched power but don't have the 12v power from the battery (Pink/Blue).
Fuses are OK, battery is good, I'm going to check the relay (no clue which it is) other then don't have any idea.... Anyone? I can easily fix it by just routing a cable from the battery to the radio and be done with it but that's not the way I want to do it. So any help would be appreciated. Thanks
I didn't check under the hood. I'll check it out. If the probable inst there ill start following the line. There is a super multiple junction where it goes from Fuse to male junction, then femal junction then to radio connector. So ill check the hood first then I'll check the junction and make sure its all good.
