No ac/heat from vents
I'm not getting any air coming out of my center console vents or the vents by each door. When I turn on the ac, air comes from the defroster vents and the two vents on top of the dash only. I recently just changed the cabin filter too, could it be dirty or clogged inside somewhere? I have the manual climate control on the car. Thanks for any help.
i remembered when i changed my cabin filter there were two power wire clips in there that i had to disconnect i'm not to sure but i think one of em is for the blower maybe you disconnected it check back chances are that you forgot to reconnect it................
if it's not that start checking your fuses ...............
hopefully this isnt the prob but on my old car any selection i made air would only come out of the defroster vents and it ended up that my motors on my hvac box were broken so worst case scenario that may be your prob but check with all you lil issues first ,fuses, wires if you disconnected any and also try a different climate control unit cuz that was a prob with my old car as well after i changed the box with all new motors it still just blew out of my defroster vents and ended up being the climate control unit was damaged
The same thing happened in my mach 1, i finally pulled the in dash and found a small vaccum line disconnected. easy fix
Check for any cracked or disconnected lines where you were digging around near your cabin filter.
Thanks for the help, still stuck though. Still no air from all 4 speeds, checked all the fuses under the dash and hood, they are all good. Actually bought a new blower motor resistor and that isn't the problem, checked all the wiring and lines, and they are all connected. Took the blower motor out and checked that with the car running and the fan cage spins fine in all 4 speeds, but didnt feel any air from the port that the plastic black hose connects to at the end of the motor(not the wiring), dunno if that's the problem?
t6378tp
Sep 29, 2018 04:27 PM
