HELP: back door wont open
so my dorrs were all working fine and dandy until sunday when i decide that i am going to give my car a full cleaning. as i am finishing up i close the drivers side rear door and it wont open from the outside. So first thing i looked at was my child safety lock and changed its position and then closed it to see if it would work... STUPID MISTAKE lol. now my door wont open at all... any ideas of what it could be... how can i pull the door off if it wont open at all?
thanks guys
thanks guys
chill? are you serious. what did i type that made you think i was overexcited.
please read before you post... how can i undo the child safety when you need to OPEN the door to change it
Keyfob would probably unlock the door but will not open it for him. Mandyfig, you are not awake yet?...
you might need some coffee...
OP, there is somebody around who was having a similar problem and was wanting to find a way to open the door panel with the door closed. I'd search to see if he found a solution.
He couldn't open the door from the outside, to begin with, before he enabled the child lock. Looks like the outside handle is the problem, but now that he can't open it from the inside either, things are a bit more complicated.
Using the keywords: "rear door panel", I found this one among others:
http://forums.maxima.org/5th-generat...door-help.html
EDIT:
Not too cool, man. An effort was being made to help you out.
EDIT:
This same thing happened to me on my wifes Passat.
I had to pick the lock from the inside. Open the passenger side rear door and look how it is possible to pick the lock with something. Warning, I scatched the fender well pretty bad so I wouldn't use a coat hanger.
Once you have the door open, then you'll have to take the panel off and figure out why it wont open from the out side.
Good luck.
Good luck.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
