Need help with stance.
Old Jul 29, 2010 | 03:54 AM
witeonblakmax's Avatar
Ok Im contemplating on buying these wheels. I have a 4thgen and the size of the wheels are as follows, 17/18 x 8.5/9.5, 56/61mm offset. I will need to run adapter 1 inch thick. Does anybody know if that's gonna be too much? The wheels already have tires on them (stretched).
Old Jul 29, 2010 | 04:14 AM
phatboislim's Avatar
you're going to need at least a 25mm spacer
Old Jul 29, 2010 | 04:20 AM
A 25mm spacer on top of the 1inch adapter?
Old Jul 29, 2010 | 05:24 AM
maybe you'll be ok, itll kick the rear out to +35.6 and front to +30.6..i'm not sure what offsets are run exactly on 4th gens, but thats not a bad setup i know on 5th gens
Old Jul 29, 2010 | 06:46 AM
NmexMAX's Avatar
dot dot dot ...
Holy positive offset batman.. I don't think those will clear your strut as is. Honestly, I would look at something that comes in a +30-35. Start out closer to where you want to be.
Old Jul 29, 2010 | 01:46 PM
Your right.. They are corvette c5 wheels. And I figured with the adapter on I shouldn't have any strut clearance issues. But yea. I'll keep looking. I just wanted some input
Old Jul 29, 2010 | 01:58 PM
NmexMAX's Avatar
dot dot dot ...
By adapter, do you mean both as a spacer and to fit them on your bolt patter? IIRC, they are not the correct bolt pattern for our cars (5x114.3).
Old Jul 29, 2010 | 02:37 PM
MetaOrbit's Avatar
Got Projectors?
I think he means bolt-on wheel adapters. He's considering a 1-inch (or about 25mm) thick adapter that will adapt the C5 bolt pattern to 5x114.3mm.
With the adapter I think those offsets would work on a A33, but I have no idea on the clearance involved in on an A32.
Old Jul 29, 2010 | 02:40 PM
Old Jul 29, 2010 | 02:45 PM
I'm just really getting into this whole stance thing. Right now I have 18 inch evo 5's but i wanna try something new. I just hate to go and buy some adapters and the wheels still don't clear
Old Jul 29, 2010 | 02:56 PM
NmexMAX's Avatar
dot dot dot ...
My I35 wheel offset hero!!11one!!!
Ahh I see. The A32 is nearly identical to the A33B (scary-similar). So I think he should be fine.
Old Jul 29, 2010 | 04:06 PM
go for it man, i hope it works out for you i'm kind of anxious to see the lines of the c5 wheels with the 4th gen body
Old Jul 29, 2010 | 04:30 PM
MetaOrbit's Avatar
Got Projectors?
I'd be interested in seeing what the setup looks like. C5/C6 wheels were never something I ever even considered because I always assumed they ran some extremely-low offset from the factory, thus making the use of adapters all but impossible.
Old Jul 31, 2010 | 04:01 AM
I ordered one adapter to do a test fit.. I'll make a thread or post it in here what it looks like.. I'm hoping they poke out alittle bit so I can utilize the stretched tires
Old Aug 5, 2010 | 12:00 AM
QT1 5MT AE's Avatar
Gram Lights addict
wur r u tryin to ahieve??? 8.5 +35 is near flush front n so is 9.5 rear
Deckdout2
Tires and Wheels
22
Sep 14, 2014 09:53 PM
BBmaxi
Dec 20, 2012 09:56 AM
IL_Maxima
38
Oct 18, 2012 07:35 PM
gtr_rider
Jun 16, 2009 03:52 PM
