Just succesfully completed 1995-1998 swap
Old Aug 7, 2010 | 05:35 AM
speedofsalt32's Avatar
So my rotted out Maxima is now in the junk yard stripped of any part worth anything. And my 1998 Is rippin' down the road. Had to switch the engine sensors, as the part number were all different even if they looked the same. The throttle body,AC compressor I switched alternators although i don't no if it was necessary and power steering pump intake heads block all the same except the fuel rail on the 98 had flat loops ant the end of the fuel rail instead of a inclined loop, my 1995 injectors work just fine Just was proud, thouhgt I would share. Love to hear about other people's swaps. nd what to do next when ya wanna go faster cheap
Old Aug 7, 2010 | 05:53 AM
Kevlo911's Avatar
Kevlo for President
should of asked first, most of the stuff you swapped wasn't needed. the sensors on the 98 are likely updated ones so keep them just incase.
and congrats!
Old Aug 7, 2010 | 09:38 AM
NemesisMax's Avatar
Congrats on your successful engine swap.
I just had a mechanic do the same to my 95 Max and now I have the engine from a 98. Unfortunately I am having many problems. The engine can't run above 3,500 rpm. It hesitates whenever I hit the gas. I'm not sure what to do or who can help. Any suggestions are greatly appreciated.
Old Aug 7, 2010 | 01:14 PM
NemesisMax's Avatar
Also, did you use the 95' engine computer or the 98' ?
Old Aug 7, 2010 | 01:58 PM
nelledge's Avatar
"I'm just sayin'..."
Originally Posted by NemesisMax
...I just had a mechanic do the same... Unfortunately I am having many problems. The engine can't run above 3,500 rpm. ...I'm not sure what to do or who can help...
Shouldn't the mechanic help you? I'm confused.
Old Aug 7, 2010 | 02:20 PM
DennisMik's Avatar
That's kinda my thinking too. Instead of scratching your hemmoroids, go give the mechanic grief and misery.
Old Aug 7, 2010 | 02:36 PM
NemesisMax's Avatar
He doesn't know why either guys. I guess I should have put that in my post.
Old Aug 7, 2010 | 02:39 PM
NemesisMax's Avatar
He's doesn't know why this is happening. I can't get info that he doesn't have. I was hoping someone here might be willing to share their knowledge.
Old Aug 7, 2010 | 02:41 PM
nelledge's Avatar
The problem with that is that the mechanic that replaced your engine knows an infinite amount more about your specific install than we possibly can. Your problem is just way too vague for a good hypothesis. Now, if you're looking for speculation and conjecture, I'm sure many will fill that need. Is there no other information you can give us?
Old Aug 7, 2010 | 05:25 PM
NemesisMax's Avatar
HELP
I have a 95 Maxima and just had the engine replaced with a 98 Maxima's engine. Now the speedometer doesn't work and engine won't rev above 3,500rpm The 98 engine was in good shape and came from a Maxima that was totaled about 2 months ago. Unlike Speedofsalt32, I still have all of the old sensors and ECM from the 95. The "check engine" light is not on so it seems like the electronics are getting along, but the way it drives says otherwise. Does anyone know if it's the sensors and ECM need to be changed when swapping engines to a later year? Can the ECM be reprogrammed?
Old Aug 7, 2010 | 05:51 PM
asand1's Avatar
Limp home mode. Did you check for codes? Sounds kinda like MAF but IDK.
Old Aug 7, 2010 | 07:27 PM
FallenOne's Avatar
HELP
3 thing that it could be, or a combination.. Throttle Position Sensor, MAF, Tranny in Limp Home Mode.
Old Aug 7, 2010 | 09:02 PM
tyler5619's Avatar
speed sensor and maf. both would throw a CEL though. does your CEL illuminate when you turn the car on? (I.E. turn key to on position, but don't start the car)
if not, you also have a blown/disconnected bulb. if you went to a shady dude, he probably fcuked a bunch of siht up and pulled the bulb so you wouldn't blame him lol
Old Aug 7, 2010 | 09:14 PM
DennisMik's Avatar
Is the CEL on? Have you checked the ECM for codes? Is the ECM the original or is it the one for the 98 engine?
Old Aug 7, 2010 | 09:20 PM
TravisCadello's Avatar
also coolant temp sensor will make it go into limp mode.
Old Aug 7, 2010 | 09:21 PM
tyler5619's Avatar
this?
HELP
Old Aug 8, 2010 | 06:39 PM
Revo75's Avatar
Holy thread hijack batman!
lol good luck with the car doing a 3.5 swap soon
Old Aug 8, 2010 | 06:44 PM
NemesisMax's Avatar
I'm not sure what the CEL is and the ECM is the original from the 95
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
Socalstillen
Sep 20, 2015 11:46 PM
Bonka
Sep 14, 2015 11:18 PM
I<3 A32's
Sep 10, 2015 11:07 AM
