A?C compressor wheel is locked.. any suggestions?
ok well i finally got my car to start today and i drove once back and forth down my street (dead end) and when i pulled in i noticed a lil smoke so i figured it was burning some surface oil well when my wife got home i started it to show her it was running and heard a horrible screeching sound like a over tight belt.. so i turn off the car i got to looking for possible problems and find out that its the a/c compressor wheel thats locked up i cant get it to turn with my hand and the belt was just melting onto it so is there anyway to un-seize that compressor wheel or am i going to have to go get another compressor ? please help and thanks for your continuing support through my car battle lol
Glad you got your car running today... But I don't know to much about A/C compressor other than you could by pass the compressor with a smaller belt until you can get that taking care of or someone suggest a better solution for you guy.... Since you got it running you don't want that holding you down right!!!
You can get a new belt part no# 350k4 and that will run you alternator
http://www.amazon.com/ArmorMark-350K.../dp/B0009XXFQY
thanks man i appreciate the help thats what i was thinking im going to try to disconnect power to compressor tomorrow to see if i can get it to spin(if it spins with power off then its the a/c compressor clutch i think) but i told my wife.. we still have air just not cold air and at least now we have a running car im just glad that i didnt buy the ecu i was gonna order tomorrow.. lol all i did to get it started was replace the battery terminals and put a 4 gauge ground wire to the tranny housing and had a good battery on it, hoked up the battery and it cranked first time
Im at work, so I cant look at the FSM, but IIRC the bearing rides between the shaft and pulley. If the bearing was simply seized, the pump would just turn. Its possible the bearing and pump are both hosed. Inspect for old belt fragments caught in the clutch, could also be rusted together. But I do believe your pump is toast.
however this doesn't mean it's the bearing. the clutch could indeed be siezed as well as the internal pistons, while the bearing itself is fine. but if that was the case you'd likely be in for a new pulley and bearing anyway (cuz it is half of the clutch mechanism). you should be able to test for this by attempting to spin the clutch plate. you should be able to spin it with key off. if you can't then you have some combination of seized clutch, or bearing, or pistons, or all of the above.
as other posts said - bypass the compressor for now while you figure it out.
well i went to AA and just got another shorter belt for it part no# 350k4 and it was a tight fit but it works great.. blows air just not cold air but no worries there i have been driving a car that wont even blow air hot or cold for the last 6 months i think i can deal for 2 weeks with this one.. now all i have to do is get another compressor and the radio trim with radio cage and get a HU and ill be done with this till it comes time for a paint job ill take pics of it tomorrow after i take it to the car wash
cool. you'll need a 92600-0L701 (or 702, maybe even 703, but not sure on this one). i have a compressor (702) with a bad bearing for sale, if you're interested in changing the bearing yourself (doesn't look like too bad of a job).
http://forums.maxima.org/4th-generat...d-bearing.html
