where is the bank 1 sensor 2? pls see my pictures
I'm sorry to ask the question again, but when I got under the car, I only saw 3 o2 sensors, not 4 as shown in the picture below:
my car is 99 infiniti I30. I only saw 3 sensors:
please point out for me which one is the bank 1 sensor 2? thanks!
1. the one closest to muffler, with white cable
2, the one close to drive axle on passenger side.
3. the one under the driver side
I went out and looked under my 99 I30 with Cali Emmisions. I have 4 sensors, One sensor can be seen by opening the hood in the exhaust manifold. My exhuast looks like the 01-03 diagram exhaust except I have a pre-cat in the front exhaust manifold. Your exhaust looks different than mine, I wonder if you have the federal exhaust.
you might be right, when I looked at the emission control tag, I didn't see califorlia, here is the tag:
is this a federal one?
I don't know from that picture. Look at the plate on the Passenger side metal plate on the firewall. The 2nd row of numbers will have either a V (cali) or U (federal) for the emissions code.
So how do I tell if my car is Cali or Fed spec?
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
Yours starts with CL...
N = Canada
V = California
Just to be clear, bank 1 sensor 2 is between the 3-way cat and the rear exhaust tube assembly as shown on page FE-4 of the 1999 FSM????
I need to get my car inspected this month and the CEL just came on. Autozone pulled codes P0138 and P0139 which is this sensor (I hope).
oh that sensor on the top behind the cat no fun on a 12 year old ny car i sheared off the entire hex with my o2 socket and i used alot of lube and a lot of heat oh well good think the sides of that pipe are flat, drill bit and tap worked awesome and now i have more tools! if anyone needs to know the tap size and drill bit send me a shout
