fog lights not working on 97 gle
Old Aug 24, 2010 | 06:21 PM
kasemodz's Avatar
I have a 97 maxima gle. It originally did not come with fog lights, however I recently acquired a fog light set, installed them, and plugged the wiring into the fog lights. I also got the oem headlight/fog/turn switch and installed that. I tried turning on the fog lights, they didnt seem to work, the head lights worked and so did the turn lights.
Now before I installed the fog lights I checked the bulbs and they seem to be fine. I also checked the fog light 15A fuse under the hood which was also fine. What else can I check? Please help thanks.
Old Aug 24, 2010 | 06:38 PM
pmohr's Avatar
No more Maximas...
Did you install a fog light relay?
Old Aug 24, 2010 | 06:41 PM
kasemodz's Avatar
I read about that, but first of all I can't find a fog light relay? Is it suppose to be to the right of ASCD in the relay box? Because I checked in the relay box and I don't see any relay next to it.
Old Aug 24, 2010 | 06:43 PM
pmohr's Avatar
No more Maximas...
Of course you can't find it, you won't be able to until you install it.
No, the relay box on the right fender, upper right:
Old Aug 24, 2010 | 09:02 PM
kasemodz's Avatar
Thanks, I opened the box and yes I do need to install a fog light relay. Can I just use the horn 2 relay to test if the fog lights turn on?
Old Aug 24, 2010 | 09:03 PM
pmohr's Avatar
No more Maximas...
A tip for Nissan relays, if they're the same color and form factor, they're identical. In this case they're both blue relays, give it a shot.
Old Aug 24, 2010 | 09:11 PM
kasemodz's Avatar
Hmm thanks thats what i figured, but it didn't turn on.
Old Aug 24, 2010 | 09:14 PM
pmohr's Avatar
No more Maximas...
Is the relay clicking when you turn the foglight switch on? You are trying it with the headlights on, correct?
You really just need to narrow it down to first, is it the control side of the circuit that's failing, or the load side? Basically, is the relay activating? If so, are you getting both power and ground at the foglights themselves?
And don't rule out a bulb that passes a visual inspection, they can easily be blown without anything appearing abnormal.
Old Aug 25, 2010 | 03:15 PM
kasemodz's Avatar
Thanks, I didnt have my headlights on when I turned the fog lights on as well. Is there any easy way to turn on the fog lights without turning my headlights on?
Old Aug 25, 2010 | 03:22 PM
neosmatrix's Avatar
http://forums.maxima.org/4th-generat...on-maxima.html
http://www.vqpower.com/v2/articles.php?article_id=31
http://www.vqpower.com/v2/articles.php?article_id=81
S
Old Aug 26, 2010 | 03:00 PM
creativeonenmb's Avatar
hook to the park lights
yes hook them to the park light wires . now all your lights can be on just did mine will add pics soon.
Old Aug 26, 2010 | 03:36 PM
tigersharkdude's Avatar
Did they work once you turned the headlights on??
Old Aug 26, 2010 | 04:04 PM
pmohr's Avatar
No more Maximas...
Except if you do that, your parking lights still have to be on.
I prefer this method, myself:
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
