okay i just ordered a y-pipe...
and looking at my VIN, my car says its a cali-spec. BUT, I have a 98 and I've heard cali-spec only applies to 99 or 99.5 maximas. I checked the stickies but i'd feel better if I got a personal response. PLEASE HELP since I have to change my order if this is a problem.
Vins don't lie.
Double check it.
AFAIK there have been cali specs since the introduction of the A32 maxima in 5/94, but there wasn't much of a difference until after a certain production date in 98 (Your production date x/97 if you have a 98) with the introduction of REAL pre-cats and swirl valves in the LIM for the cali-spec models.
Even if you ordered the Y-pipe and said it was for a 98 cali spec you should be fine....
Pop your hood, check for LARGE can on your front header, if it's there then well... I hope you ordered a cali spec y, if it's not there then don't worry.
Double check it.
Chances are that if you are a 98 model year that you're like 95% of 4th gens and don't need the special y pipe.
Only ones that require the shorter Y pipe are 99 Cali specs, all 95-98 Fed/Cali spec and 99 Fed specs use the same pipe.
And if you do have the precat in the front manifold, swap it out with a fed spec manifold. Its not difficult and will yield best gains.
220k+ A32
25
Oct 3, 2015 09:09 PM
bigfrank
Oct 1, 2015 12:51 PM
Pied
Sep 26, 2015 03:29 PM
