could this guy (harness) couse p1400? see pic
last time when i replaced knock sensor i noticed that i am able to pull this cable from socket (green). Looks like someone in past tried to solder it but it didn't help, so I've put it back in place, recently i am getting CEL P1400 (EGR valve) and sometimes p0400, could it be because of this harness? if not ,what is that for anyway? ow and it is 98 SE
close up:
close up:
If the code was never there and it came up after you touched it, then yes, it could be the harness itself. You will need to go to the JunkYard and cut off one and splice it in. That is the EGRC Solenoid Valve and with that code, you will not be able to pass emissions.
Yes thats the EGRC and it will cause a P1400, you can ohm it out to see if its good or bad. Let me search for a post I made last year and I'll get back to you with the info
A lot of scanners will say its a Manufacturer code or some bs like that and it wont tell you what it is
Here ya go, this one even has a few pics. Good luck
http://forums.maxima.org/7215367-post61.html
http://forums.maxima.org/6429395-post5.html
Sweet. i checked and it was around 38 ohm when warm, so only problem is this socket, going to visit junk yard soon. Problem solved thanks!
, but i needed car...and it was Maxima and it was fully loaded , and low millage, and looked good, and seller said the smell is only because car wasn't used over a year!!
and i was so tired of buying/searching and so cheap not to check carfax.But, it is driving good , i replaced lately alternator. I'd Better clean my groundings until another die. what else should i do/check with this "kind of car"?
Umm, I have rust on my clamp and my car has never been under water. I do degrease and wash my engine bay which could also cause rust...not only flooding.
However, that doesnt matter because you were referring to the OP
OP, glad I was able to help. Now if someone would be nice enough to help me and infowire with infowires problem. We are fresh out of ideas! Sorry to "hi jack" but its really annoying me not being able to figure the problem out!
http://forums.maxima.org/4th-generat...d-lagging.html
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
It doesn't take long for a car to distintegrate with all the salt they throw on the roads in winter here. I imagine Connecticut is just as bad.
