What does your max idle at?
Old Sep 14, 2010 | 07:03 PM
xtremepb0's Avatar
For some reason looked at the rpms the other day while I was at an intersection and I was idling at 500 rpms this seems kinda low in my opinion. Is this normal for you guys? If not is it a big problem and how should I fix it? Thanks in advance
Old Sep 14, 2010 | 10:11 PM
asand1's Avatar
1200 cold and 700 warm. I think auto is supposed to be 500. If it runs smooth don't worry about it.
Old Sep 14, 2010 | 10:21 PM
Your car is definitely idling low. I'm auto and cold I idle at 1500 and when it warms up I'm at either 700 or 800rpms.
Try cleaning your TB, that should help.
Old Sep 14, 2010 | 10:36 PM
aackshun's Avatar
That's low for even a manual, which by FSM can idle the lowest.
Recommended, no load, warm idle varies a little bit by years but still is around...
MT 550-650 rpm.
AT 600-700rpm.
Weather outside controls my idle (sometimes I can predict the weather based off of it)...
550 for good weather days and about 700 for bad days.
And warming up... My car has idled @ 2k many times before, but those days were extremely cold..... Houston has never seen any temps near what the car saw in KS, the highest I've seen it idle down here is 1.4k, and that was once. Usually the first start of the day it roars to 1.4k and calmly backs down to 1.2... then lower and lower....
Old Sep 15, 2010 | 05:32 AM
Trini Boom's Avatar
I am auto with 1400RPM cold and 650RPM warm.
Old Sep 15, 2010 | 06:09 AM
99greddymax's Avatar
1200 cold start up...
650 idle up to temp
950 with ac on
6550 RPM at WOT
Old Sep 15, 2010 | 06:22 AM
jholley's Avatar
My auto idles at 1200rpm cold & 600rpm warm.
On a warm engine just open the IACV adjustment screw a little further to increase the RPM. It's a black plastic screw on the top left of the Idle Air Control Valve.
Old Sep 15, 2010 | 07:15 AM
Zalley's Avatar
I idle at 550 as well , I am thinking its my throttle body.
Old Sep 15, 2010 | 07:21 AM
you need to also disconnect the tps, and make your idle adjusment via the IACV.
Old Sep 15, 2010 | 07:50 AM
Zalley's Avatar
If I give my maxima some gas , and revv above 2k rpms and let off quickly the idle drops to 4k and stalls a little and comes back up , what could this be?
My maxima idles at 550 rpm with no AC and I usually put my ac on 1 so it idles correctly (700-750 rpm.)
cashoit's Avatar
Old Sep 15, 2010 | 07:56 AM
Zalley's Avatar
yezzir Im a newbie lol just got my 96 auto a month ago.
Old Sep 15, 2010 | 09:01 AM
Definitely try cleaning your TB and get back to us.
Old Sep 15, 2010 | 09:24 AM
Zalley's Avatar
based on this you think its most likely the dirty TB?
Is there a good write up link on cleaning th TB? the one in the how to does not work. and on my honda you just unplug IACV (not even sure my max has IACv since its auto...) and take off 4 screws and 2 hoses and its done. looks a bit more menacing on the max.
Old Sep 16, 2010 | 07:41 PM
speedofsalt32's Avatar
mine's here too but i turned it up a little wanted all the slack out of the throttle cable as possible
Old Sep 16, 2010 | 07:52 PM
Leo_Koneval's Avatar
My car used to idle a bit high and so I lowered the RPM with the IACV screw and then after cleaning the TB it went back to stock idle. LOL
So here is the low down:
Cold RPM-1200
Warm- 800
In gear- Somewhere between 500-600
I thought lowering the RPM would save gas, but it didn't make much of a difference
Old Sep 16, 2010 | 08:06 PM
K31J1m0N's Avatar
just adjust the idle air screw
Old Sep 17, 2010 | 06:22 AM
jholley's Avatar
Scroll down this 'HowTo's: 4th Generation Maxima' thread and you'll find plenty of write ups on how to easily clean the throttle body, IACV, MAF, EGR......
http://forums.maxima.org/4th-generat...on-maxima.html
Old Sep 17, 2010 | 07:11 AM
1997MAXZ's Avatar
650
Old Sep 17, 2010 | 07:16 AM
99sagelimited's Avatar
I'm at 900-1000 rpm cold & 600-650 warm. (A/C off)
I have a manual tranny too.
Old Sep 17, 2010 | 07:20 AM
I had the same issue that was fixed by replacing the knock sensor. I also had hesitation around 2000-3000 rpm. I would check for codes. I had a knock sensor code for awhile that didn't throw the check engine light. Do you have any power loss? Poor gas mileage?
Since replacing my knock sensor, all of my issues have been resolved...hesitation, idling issue, and poor gas mileage.
Old Sep 17, 2010 | 04:23 PM
Mistah_M's Avatar
i got automatic. in the morning its usually around 1500. durin the day its about around 700
Old Sep 17, 2010 | 04:57 PM
tigersharkdude's Avatar
cold mornings ~1200
any time warm ~500
Old Sep 17, 2010 | 08:19 PM
Kico's Avatar
1200 cold warm 650-750 and I have 00VI
Old Sep 17, 2010 | 11:09 PM
illmortal's Avatar
Strangely... my auto is 900-1,000 warmed up.
This is on a 4th gen.
Old Sep 18, 2010 | 12:43 AM
96i30azn's Avatar
^vacuum leaks cause high idles, or your car's idle simply isn't adjusted
Old Sep 19, 2010 | 05:08 PM
NeptuneMan's Avatar
1000 on my manual, and around 1300 on my auto. I live in Oklahoma, if that tells you about the weather =p
Old Sep 19, 2010 | 05:10 PM
NeptuneMan's Avatar
Speaking of gas mileage, I'm new to the forums, what kind are you getting? I feel like my 98 maxima auto gets about 21 mpg. I feel like I keep it fairly well maintained, so I'm curious what others are getting.
Old Sep 19, 2010 | 05:18 PM
xtremepb0's Avatar
Hey guys just thought I'd check in. The past couple of days I've been monitoring my rpms since it was so low when I first posted this strangely it fixed itself 1100 cold 650 warm. I drive manual btw
Old Nov 30, 2010 | 10:17 PM
SteveSample's Avatar
What is the tps and how to disconnect it?
How do I disconnect the tps ( throttle position sensor?) to adjust the IACV? Thanks, Steve
Old Dec 1, 2010 | 06:52 AM
LtnMAXX's Avatar
Old Feb 25, 2018 | 02:54 AM
Thanks. Cleaning the TB helped.
Old Feb 25, 2018 | 04:24 AM
max ride 41's Avatar
8 y/o thread.......
TKHanson
Nov 24, 2018 01:39 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
