Need To Raise Idle (Please Respond Quick)
Hi Guys,
Just wanted to know how to raise the idle of my car a tad. It's idling kind of low the past couple of weeks. I am really dumb when it comes to under the hood. Can someone please tell me where the screw is and where is the Throttle body? I know the screw is near the throttle body but I don't know where the throttle body is (How Sad). A quick response would be really appreciated. Thanks a million.
Re: Need To Raise Idle (Please Respond Quick)
Originally posted by pimpofbrooklyn
Hi Guys,
Hi Guys,
my answer will only be any good to you if you have a VG..the thing with the 2 round things with the cables connected goin to the back of the engine bay..well the thing that the round things are connected to...that your throttle body,the screw may be covered with a rubber cap,maybe not..too late and cold to go look at my engine...hope it helps,explained it in as easy terms as i could
a little late. but check this thread out. i had some instructions there.
http://forums.maxima.org/showthread....djust+and+idle
There is a small screw driver hole in the computer under the dash behind the centre bit where the transmission shifter is located. I did mine there. Adjust the screw till ur idle is where U want it.... Hope this works..
Unclejunebug
Apr 2, 2016 05:42 AM
