Ram air intake on a 6th gen .. anyone ever done this ?
So i was just curious cause i wanted to try this out
having a ported / custom intake manifold makes you lose power unless you have forced induction ....
what if you do a ram air intake system on a ported intake manifold ?
good idea ? bad idea ? worth a shot ?
and im aware of not being able to drive in the rain and have a solution to that aswell
first off our cars come with ram air intakes stock. ram air comes in through the front right under the hood/grill. Poorly designed IMO, however it is ram air. the reason you loose power with a ported intake is due to the ECU learning feature. Port the intake and get an engine management system. Even a better designed top mounted ram air intake will do the same without a Engine management system.
vingodine
45
May 21, 2016 12:46 PM
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
