A/c compressor bearing
I replaced mine 2 years ago and got it thru these guys...
http://www.xtremeac.com/Products%5C1%5CNissan1.html
I changed the compressor some time ago and it still works perfectly, but the bearing in the compressor is really loud because of its age im guessing. I would hate to have to change the compressor and have the system flushed again for just a bearing.
2.44 in. (62 mm.) outside diameter x 1.57 in. (40 mm.) inside diameter.
This was my bearing size. But from what I read, there were 2 different compressors (bearing sizes) in 4th gens.
So you'll be able to change the bearing while it's on the car? Once you disconnect those hoses, you will have to have the system flushed again unfortunately.
i replaced mine.. its a *****.. the clutch doesn't like to come off after its off just replace the pulley with the bearing as a unit..
i went to the junk yard found a maxima that the pulley didnt make noise on and called it day.. been fine for like 3 years
You can use a steering wheel puller to remove the clutch. Shouldn't bend or maim it that way. You got lucky getting one from a boneyard (and it not squeaking) - it's a risk, but sometimes it can work out.
There are two diff sizes - this is correct. IIRC, 95 - 96 they used a diff bearing than that of 97 - 99. All I can say on why is ...
litch
123
Jan 4, 2024 07:01 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
