To Buy or Not to Buy!
Found a Max for my bro, its a 98 137k on the clock guy is asking $3200. It starts up fine idles smooth tranny shifts smooth ...
needs tires and brakes all the way around, some random suspension parts probably do inner and outer tie rods and there are a couple of oil leaks i want to try and identify.
i couldnt see under the car well (will be going back to take a better look) but leaks are as follows:
both valve covers, on the side of the engine at the water pump / water outlet hose. (i believe it's oil not water not 100% tho) and i could see oil on the front side of the oil pan not sure if its the same leak as i couldn't get under her very well.
yea it has no options its the base model my bro was disappointed as mine has all options lol, i was expecting to talk him down a bit
im most worried about the oil leaks we can to the rest of the work easily.
i agree i was looking to pay 2500-2800 IF the oil leak is a 5 10 min fix not the timing O-rings problem if its a big job my bro will wait for the EXACT max he wants then consider fixing one that has issues...
That's way too much for what it needs. I got my fully loaded '96 SE with 84K miles for $2500 and all it needed was for the brakes to be re-greased and to fix the leak in the flex pipe.
$3200 is too much for all that needs to be done, and it's a high mileage base model.
no more pics
... both front and rear valve covers were leaking i could also see oil on the front side of the lower oil pan but i couldnt see up any further to see if it was the same leakwhat would cause the leaks? my is also a 98 more miles and its dry...
Common oil leaks are timing cover o-rings, valve covers, upper oil pan gasket, crankshaft oil seal, rear main seal and oil pressure switch. From the sounds of it, you would have to completely change all seals on that engine. For that price, if you are willing, then go for it.
got mi max for 2300,its a 95 bone stock(when i got it) needed brakes tires fix oil and water leaks from both pumps suspension work fuel pump and filter oil change, spoiler needed a proper instal ,and a **** load of electromechanic work the bose did not work and blew like 4 fuses evry time i hit a bump..it was hell...but all the leather, dash, sun roof, body and stock nissan 5 blades were perfect
did all the work myself
and its ben like 3000$ on parts (and extras
i live in puerto rico not that many here and i love the car dearly so it was a rip off but i was smiling the whole time my pokets were empty
)i live in puerto rico not that many here and i love the car dearly so it was a rip off but i was smiling the whole time my pokets were empty
I bought mine almos 4 years ago, and you would not believe what i paid for,
and it only had 80k, the only problems it had where, axles, radio, and bad paint, started to oxidize, rear valve cover. And i paid 8000, i dont know why, i just didnt know anyother MT like this. I even wasnt looking for a maxima that day
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
