NJ FS: Engine Parts
FS: Engine Parts
A few weeks ago, I broke a ring in my 2002 VQ35. I replaced it with a low mileage junkyard 2007 engine.
I transfered all of my old parts to the new block, so I am left with pretty much a complete 2007 engine (with the 2002 block -low compression in one cylinder) available.
The front valve cover, and the cooling lines in the front and between the heads has been sold already. Everything else is still available.
Please contact me with requests.
Sorry, No. It was not on the engine when I got it. Popular item, I see..
Sorry, no. Just got the engine from the junkyard.
If it is part of the engine, I probably have it.. Can you give me a better idea what it is? photo maybe?
Lots of other good stuff, for anyone looking.. Complete wiring harness, complete front cover, timing gears/chains, oil pan, starter gear/flex plate, heads should be good too. Block is a good "core" if someone wants to replace the broken ring.
http://forums.maxima.org/6th-generat...ias-plate.html
If you look at the pics in post 2 the plate that says NWP. Well in a stock car, it should be in the same place and have some hoses attached and stuff. If you detach that plate, there should be a butterfly sorta like the throttle body butterfly. I only want that piece with the plate and stuff. I dont want where the hoses lead to, just the plate thing and i guess the hoses.
can anyone help me??????????
i just got an 05 maxima 3.5 sl with 85k miles and i got it pretty cheap due to the fact that it need motor mounts (the car kicked when shifting from 2nd to 3rd)....ive replace the mounts and the car still kicks....the gears are smoth no problems shifting but can it still be the trans? ive taken it to nissan and they tell me nothing is wrong but why does it kick so hard? my neighbor has a 04 maxima and his kicks as well are the supposed to kick like that when shifting from 2nd to 3rd?
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
Team STILLEN
Aug 10, 2015 04:29 PM
BassAddictJ
Aug 4, 2015 11:38 AM
