4.5 Max tuning tips needed:Dyno proven maybe?
Guys,
first off i have read some stickies and wanted to see if any one outhere had some helpful insight as to what im trying to do.
I finally got to tuning my 4.5 via safc2, was running really rich without corrections and I have it in the 12.3-12.5s range after a couple days of playing around with it.
I know every car is different, but seeing as many guys have done the 3.5 swap, maybe someone outhere already has spent some time on the dyno , even the 5.5 guys, and have seen dyno results as to how lean to get or the point where leaner isnt really making more power.
I have asked a couple guys , one said 12.8s, Eddy 95blckmax said 13.7s lol you can see the diff.
car has the basics
short ebay header/y
test pipe w cutout
2.5 catback
in fender cold air
vis delete plate
5 sp stock rpm stock ecu w safc2 fuel psi @ 51 lbs , walbro,
trying to save time on the dyno hence $$ so im trying to get to the dynoas close to the ideal afr as possible.
oh and if you guys have any little cheap mods worth the money vs power ratio i may not have let me know .
car has the basics
short ebay header/y
test pipe w cutout
2.5 catback
in fender cold air
vis delete plate
I think both jime and aaron both run theirs cars in the 12.8-13.1 range also
edit: almost forgot my G35 is tuned to 12.8-13.0 range with max timing 32degree's forget which rpm be it was in the uppers rpms and it was in 26-28degree in the mid rpm range . The car didn't make anymore power going any leaner or with more timing. I had a vp104 race fuel map but was since only able run 34degrees of timing and only gained like 4-5hp and at 9bucks a gal wasn't worth it to me so I erased it for a nitrous map. I gained power across the entire powerband along with 8hp peak and 14hp/16tq in the midrange. Hope this helps
mods were testpipes, intake spacer and z-tube
yeah guys, you were right, the car made the most power at 12.9-13.0 and thats were i left it. i took out 1% accross the whole range , and then i lost 2-3 ponies, so i brought it back down. Im not super excited about the numbers, but for not having spacers, or real engine mods i was content. the cutout was worth 10 whp and didnt show any loss in bottom end, in actually it made about 1-2 more hp on the low end as well.
the cutout sits low so im going to decide wether i drop n cams to help the curve stay up with a 3inh y and catback( it peaks and drops back down after about 5800). or ill decide on boosting. still on the ropes about it.
btw, I would boost it 8psi and a stock rev limit that motor should last ever or a jwt ecu/eu, ssim and a 3inch exhaust.
hr springs or crower springs, def going to do the pump
Stock springs on stock cams, yes. Aggressive cams will cause the valves to float beyond 6,500 RPM without a stiffer valvetrain. And on VQ35s after 7200 you'll wanna at least upgrade rod bolts and main bearings.
are the hr springs better than de? i dont plan on reving past 6850 or 7k max, seen too many bearing failures with guys revving 7200
kinda would like to think im buying a pump bc its somewhat proven better kow what i mean
Nobody mentioned double shimming the HR springs.
Rev up Z = 7100 vs 6550 from the factory.
These were the prices 2 years ago:
Springs-
24@ 4.14ea- $99.36
Shims-
48@ $1.24ea- $29.76
Springs-
24@ 4.14ea- $99.36
Shims-
48@ $1.24ea- $29.76
or so it "should" cant be more than a week as i will need to drive back up here
heres a dyno pull and a 370z 3rd gear run
http://www.youtube.com/watch?v=C1y2FlQ7x34
http://www.youtube.com/watch?v=GH6yLKw4Lgg
zzznightmarezz
Sep 21, 2015 06:32 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
. Initially he was only going to give me one set ... so you're right, that's the price for double shims.
