Sponsored by:
Sponsored by: CARiD
Is there a aftermarket TCU for us?
Old Dec 8, 2009 | 06:04 PM
My-Body-Is-Ready's Avatar
I have vq35hr built heads, (cams, valve springs, shims, retainers) but i feel like im not even puttin them to use with my 5spd AUTOTRAGIC. The car shifts at 6400 no matter what. In tiptronic mode, unlike the 4spd autos, the car shifts when it hits 6400. I do have a tsquare ecu reflash with raised 7100 rev limiter but thats only in neutral. The tsquare does not control the TCU.
I looked at jim wolf but they only make it for the vq30.
any help is appreciated.
Old Dec 9, 2009 | 09:14 AM
Kevlo911's Avatar
Kevlo for President
Supra Stick should be able to work.
BTW: any details on this HR stuff? Or did you just put the newer Altima heads on your block?
Old Dec 9, 2009 | 05:30 PM
suprastick is for the 4spds. i have a 5 spd auto.
details on the HR stuff? i think this has been done quite a bit already its nothing new.
Its from a 350z with vq35HR motor.
My motor is just moderately built with cams from the HR, valve springs, double shimmed, and retainers all from the vq35hr.
Old Dec 9, 2009 | 05:47 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I think the confusion here is that your first post seemed to imply you had full HR heads.
Did you get the OEM HR cams for cheap? Do you have specs on them?
Old Dec 10, 2009 | 05:33 PM
here ya go sir
http://www.jimwolftechnology.com/wol...INCL_REVUP.pdf
Old Dec 10, 2009 | 05:40 PM
Seems rev up cams would have been better, if you had to go with stock cams.
Old Dec 10, 2009 | 07:30 PM
tuko316's Avatar
phill, you need to meet me at harjits shop. ill be there tomorrow during the day. i know a trick with the autos i learned when i worked at the dealer.
Old Dec 13, 2009 | 08:32 AM
po8pimp's Avatar
why not share the trick here on the forum
Old Dec 13, 2009 | 09:40 AM
streetzlegend's Avatar
Only thing I can think of is messing with the TPS signal going into the TCM, but I am pretty sure it will only affect part throttle and not WOT since at WOT, even if you had higher voltage going into the TPS input on the TCM the table is already maxed out at 100% throttle.
Old Oct 31, 2010 | 03:04 PM
grey99max's Avatar
LandShark has Cosworth
How about this?
http://www.importperformancetrans.co...kit-155-1.html
Or these guys?
http://www.levelten.com/SearchResults.asp?Cat=37
chisam14
Nov 6, 2018 08:56 PM
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
