Amp shut off at high volume
ok so today i got a new system audio pipe its a package there made for each other so nothing can be over powering or under powering. so when turn the volume up to like 18 it shuts off when i turn the volume back down the amp turns back on. i have no clue with the problem can be. is the amp defected or do i have a wire problem?
its a audio pipe 2 channel 1000watt 2ohm stereo stable, 4ohm mono stable
this is it
http://www.usaudios.com/products/Aud...f2027316160355
what speakers do you have and are they wired in parallel or series? is the amp running in bridged mode or stereo? most likely your subs are wired wrong and the amp can't handle the low impedance and the amps cuts off.
every thing is audio pipe the amp is in stereo mode each speaker is 2ohm the amp is 2ohm stereo stable and 4ohm mono stableit cant be low ohm impendence because I bought it as a package eveeything was made for each other
here's info on setting the gain
http://mobile.jlaudio.com/support_pages.php?page_id=143
http://forum.realmofexcursion.com/am...al-2010-a.html
hayne
Oct 5, 2015 11:53 AM
