Rattle
Old Oct 24, 2010 | 01:12 PM
Country24's Avatar
Rattle
I have a 02 max with.143xxx on it, and I am getting this rattling noise. When I start the car when it's cold it doesn't do it, when the car is warm while it's in neutral idling I give it a little gas and it makes a rattling noise. I checked the exhaust system and the heat shield still getting it. It sounds like it's coming from the engine or underneath. What could this be? Thanks
Old Oct 24, 2010 | 01:20 PM
zero2sixtyZ's Avatar
You embarrass me.
how's your oil level?
Old Oct 24, 2010 | 05:24 PM
Country24's Avatar
It's good just had a oil change and I don't loose any kind of oil
Old Oct 25, 2010 | 05:21 AM
Gizm0's Avatar
Most likely your precat needs to be replaced.
Check this thread, does it sound the same?
http://forums.maxima.org/5th-generat...er-reving.html
Old Nov 6, 2010 | 01:10 AM
Saadkhan07's Avatar
re
the rattle i heard is all pre-cat. this is i think, simply not cool ! but ill bear with it....
Old Nov 6, 2010 | 06:07 AM
Gizm0's Avatar
I drove with the rattle on my car for a year. It didn't hurt anything but it was annoying, especially on a stick shift. Everytime I would let go off the gas while driving, and the engine was b/w 1000 and 2000rpm, I would get the rattle...
The inside of the cat just came loose. It didn't break in pieces or anything, but the entire thing inside was loose and no longer attached to the metallic shell of the cat.
tip: if you need to replace your cat, ask your mechanic if you can get the old one back. I brought mine to a recycling place and got $70 for it
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
