When adding or changing oil, have you ever noticed...
...what happens if you "miss" the oil fill hole in the valve cover?
If you get sloppy and some of the oil drips outside of the filler neck, have you noticed where it ends up?
I did it tonight, didn't think it was that much, a few drops.
Went straight down and landed on my alternator. In fact, it hits the electrical connection on the top of the alternator as well as going right into it.
I wonder if that would explain why so many alternators die an early death?
<knocking on wood, hope mine survives>
knew I shouldn't have been changing the oil at 9:30pm in the dark
Just did that, it flushed a lot of OLD crap off the top where the connector is.
Probably inside the alternator as well. I obviously wasn't the first person who has done that to this car.
Left a big dried-puddle of oily residue on my driveway.
Things happen..Try Techniseal's degreaser for your driveway.
So on the way to work this morning I was a little worried about the alternator.
I stopped at Wally World and for $15 picked up a nifty little digital gauge that plugs into a 12v outlet in the car and gives a constant readout of the charging voltage.
It was all good at 13.7-14.1 charging volts.
Kind of a nice thing to have in the car, has anyone installed a permanent volt or amp meter in their Max? Our cars need more intelligent gauges than Nissan supplied them with.
I do like the little gadget, I might pick one up for that price to have on hand if needed. Didn't know they had such a thing.
Edit: Did you check behind the plastic cover, you know the one that covers the top of the engine, for more of the oil?
No leaks on mine, just oil that missed the filler spout and ran down the block to land on the alternator.
J-Rod, they also make one that actually fits on the battery post and gives a digital readout as well.
Problem is, you can only see it when you have the hood up...
My engine gets dusty looking after a year or so, mostly from our extremely dry climate and the road sand they use in the winter. I just don't like it looking like new under the hood. I also had a leaking high pressure PS hose this year too that built up a nice layer of gunk around the back and passenger side of the engine. Oh and I also had a battery that was leaking acid before I could get to it. It's always something.
My missed oil (from when I'm adding a half quart on the go) always pooled up on the indentations created for the spark plug boots/ignition coil/whatever the proper name is for that top piece that sits on top of the engine. I found that out when I took the cover off to clean it. I was a little panicky at first, but then realized that oil wasn't magically coming out of the spark plugs--it was 100% user error.
doctorpullit
Jul 20, 2019 09:31 PM
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
