oem 5.5 navi swap out help
Ok well im going to swap out the oem navi unit for a Pioneer Avic Z120BT
can someone inform me on whats needed, im getting conflicting views on what is needed!
besides the auto climate control
can i use my oem 1 piece ac vent/ navi housing shell to house the Z120bt, or must i get the ac vents from a Se and swap mine out?
so far I have ordered
Metra 70-7551
Scosche Ndab nissan diversity antenna adapter
Axxess Metra ASWC OEM steering wheel control adapter
Metra 70-7551
Ok not much help here.
I now have most of what I know I need!
My question now is, has anyone or does anyone know how to swap the climate control and what wires need to be soldiered? thats all i need to know now!
thank you very much
thank you very much
I will get a few pictures when I get it all done up!!!
i've heard its not a hard job at all, but all i need to know what wires and colors pair up. my installer and I will get it done!
^^I'm that installer. I've already started matching the wire colors between the two FSM's.
I will be posting a wire color mapping document when I'm done. Just another innovative product coming from the mastermind of djfrestyl
we can work out a price
this will be the man to do all my install work for my audio
and i would def say for everyone to do the same, great guy and knows what he is talking about
and yes man we will def take pics of the wire up of the auto navi climate control, to regular auto climate contol so everyone knows and wont need to run around like a chicken with their heads cut off like we was for a while!
good luck with the swap. I'm jw though was there something you didn't like about the oem navi or did you just want to swap out with something else? jw...kinda wished I always had navi..don't really see a reason why I would take out factory navi anyways haha. GL
whatever it came with will all come out. i might sell the oem navi I'v had 10 pm's for it already here and 4 on ncmaximas.
I am in the same boat as the OP.. I have searched and have found one thread where " GodFather " did such swap from OEM navi - aftermarket..
Here's the thread. -
http://forums.maxima.org/5th-generation-maxima-2000-2003/359817-navigation-doble-din-vs-gxe-double-din-kit.html
I have sent him a PM and have had no response..
I hope you have better luck with this. IMy OEM navi is a POS! the AUTO climate control button fell off and I have no AC/Heater..
Please post up picks and a wiring diagram.
You have to get the FSM's from both the navi and non-navi version, and match up the wire colors / functions of those wires. What's good is that the wire colors hold the same function between the two versions. They're just on differently shaped harnesses.
It's basically a mapping exercise.
I also just PM'd GodFather. He's been active on the forums so hopefully he has some insightful info. I'm capable of doing this, just need some additional information.
Response from Peter (GodFather):
Helps, but additional info still needed. Once I get in there I think it will simply come to me
Originally Posted by godfather
But if you figured out the wires, then it's down hills from there. I do remember vaguely that I couldn't get the illumination to work, so my auto climate control isn't backlit at night, I think this is due to a grounding issue. Also, the mode button on my steering wheel wouldn't work anymore due to the same grounding issue. Other than that, most of the wires are done from the small control module at the lower left corner of the floor once you open up the NaviDash area.
I'm looking to swap out my Navi as well the guys at car toys said its impossible, but if I can show them maybe they can do it. I don't know anybody where I live (Colorado springs) so that's unfortunately my only option.
Also, I found a climate control that I wanted to put in fro
Another '03 max on eBay, where the 6 disc changer control goes. Is that where you will be putting the climate control?
Thanks in advance! Look forward to the final product!
Update!
I have all the information necessary for someone to do this swap. I've done ALL the research, and have mapped out all the wire colors, pin locations, etc.
Unfortunately the OP has decided to sell his Maxima, which means we will not be performing this project.
This does mean that all the parts necessary are now for sale:
center vents
radio brackets
auto climate control pigtails/harness
Please PM me if interested, I am selling it as a package. And I will also include the spreadsheet which I created that has all the wiring information. It will make performing this job very easy.
center vents
radio brackets
Hey im kinda new here and I know this is an old thread, but do you still have the spreadsheeg for the swap. My navi was ripped out an harnesses cut, the stock navigation for the 02 max seem to be hard to find. I already have the ac/heater control + harness.
