Still searching for oil filter"condom" to keep from making a mess during DIY change
Any brilliant ideas from the crowd?
I've tried the suggested plastic bag over the frame that gets dumped on...tried aluminum foil and most recently tried a ziplock bag, but always end up still making somewhat of a mess. If I could just find something with some kind of a rubber band opening at the top that would seal all around that opening, then with some kind of bag on it, I could just seal that elastic part over the opening and then unscrew the filter, letting it fall in the bag. I would welcome any more creative ideas
I use this oil deflector to drain the oil and it doesnt make a mess, heres a link:
http://www.handa-accessories.com/crvmaint05.html
edit: you have to scroll 3/4 down the page.
Here's what I designed back when I was a lube tech. It's an Antifreeze bottle.
Cut it exactly the same way, it will slip up in between the sub-frame and the oil pan just touching the side of the filter leaving enough room to grab and unscrew the filter.
When you loosen the filter, the oil will drain down out of the the lid hole into your oil drain pan leaving no mess on your sub frame.
Install your new filter, slide it out and wipe the excess oil just under the filter.
When I posted the issue of oil spills due to the oil filter, someone suggested to install an oil filter re-location kit.
Example: http://www.perma-cool.com/Catalog/Cat_page27.html
This weekend I did my first oil change with Mobile1, I pulled the wheel off and removed the one plastic cover, used a peice of cardboard, shaped it, didnt get one drop anywhere but the collection pan.
Im glad I read this post before doing it though
yeah, i knew where the filter was, just wanted to make sure i was clear on which direction you had the oil draining...whether it was draining the same side as the filter sticks out, or if it was draining back the other way. i haven't been going to the trouble of taking the wheel off or taking that plastic guard completely off...have just been undo'ing the bottom pushpin of that guard and working my way in there...that's probably part of my problem...I should probably just pull the wheel and take that guard completely off to give myself more room.
I just shaped the cardboard toward the tire (which was off) over the frame, right into the pan
Works great and adaptable to any auto.
Uploaded with ImageShack.us
Slamrod
Apr 10, 2016 05:24 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
RealityCheck
Aug 5, 2015 06:18 AM
