Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
How to revive Weatherstripping
Old Dec 16, 2010 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
I can hear random air leaks when I am driving and I was wondering what people do to rejuvenate the weatherstripping. Any kind of special products? Or just some rubber/vinyl protectant?
Or any sources for replacement weather stripping? OEM = EXPENSIVE
Old Dec 16, 2010 | 08:41 AM
I clean mine with those Magic Erasers then coat them with spray wax. Seems to work pretty well.
Old Dec 19, 2010 | 06:34 PM
Kevlo911's Avatar
Kevlo for President
hmmmmmmmmmmmmmm
is there anyway to help it get its bounce/spring back?
Old Dec 19, 2010 | 06:42 PM
Originally Posted by Kevlo911
hmmmmmmmmmmmmmm
I've never looked into it but I'm sure there is. Re-conditioning it should help.
Old Dec 21, 2010 | 12:18 PM
gdal's Avatar
Clean them with APC(all purpose cleaner) like Zep Citrus (sold at Home Depot) and then apply some silicone lube (sold at any Auto Parts). Use a microfiber to rub the silicone until it disappears. You can also use a trim dressing, but make sure it's water based. I used to own an Aurora with frameless windows and I had to do this every Fall/Spring.
Old Dec 23, 2010 | 06:02 PM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
My favorite trim dressing is Mother's Back to Black... according to the marketing it can "revive" worn weatherstripping but I doubt it will do much to make it "bounce back."
Old Dec 23, 2010 | 08:32 PM
maxima07's Avatar
Poorboys trim restorer.
Old Jan 6, 2011 | 06:37 PM
niceguy's Avatar
May sound goofy, but someone told me about using Vasoline on the weatherstripping and it worked pretty well on a friend's older car....
Old Jan 11, 2011 | 09:22 AM
350zMaximaownr's Avatar
Op appears concerned about the noise, not aesthetics. If thats the case, ya use the old $ bill method....close your door jam around folded bill and slide through door ways so you see where your "loose spots" pun intended are, and bend the door slightly by bracing with knee and pulling with arms.....old school yes, effective....you bet your @$$
Pm or reply if still confused
Old May 19, 2011 | 08:07 PM
shadyonedeath's Avatar
i would like to try this but am a little confused. Could you re explain that?
Old May 29, 2011 | 06:34 AM
itgogitrev's Avatar
If the weather stripping isn't springy or sealing, it means that the substrate is cracked or fatigued. It's like looking at a dented fender and asking what kind of wax will pull out that dent... you really just need to replace the weatherstripping.
If you want to try it, I put silicone spray on my weatherstripping about once every two months. Seems to help it along, but I know that mine needs to be replaced too.
2004 Smoke
Jan 19, 2006 07:43 PM
FunLovinMaxima
Dec 1, 2005 01:27 PM
Slamnasty
Jul 12, 2005 05:14 PM
