2000 Nissan MAx start up issue
Old Jan 30, 2011 | 10:16 AM
aleem's Avatar
I have 2000 max with about 160k miles on it. it been giving me some hard starts recently until today it turns over but doesnt run. I want some ideas so i can continue trouble shoot. during cranking i get insanely loud back fire. the car has headers and 2.5 pipe all the wato back with no cat or resonator. the car has been running great except for starting issue. i am going to see if i can do a compression test....
this is what i have done so far.
I have header none of the o2s work. those are the only codes im getting.
new spark plugs i bought today
fuel pressure test came out good
welded a crack in the header
checked all coil packs
check to make sure cam shaft is turning(tought timing chain broke)
Old Jan 31, 2011 | 08:46 AM
aleem's Avatar
anything?
Old Feb 1, 2011 | 12:37 AM
aleem's Avatar
close thread. turns out crank sensor died
Old Feb 1, 2011 | 03:22 PM
Amave's Avatar
which one?
it has 2 ckp sensors
Old Feb 1, 2011 | 05:44 PM
aleem's Avatar
the one under crank pully. p1335
Old Feb 6, 2011 | 10:55 AM
aleem's Avatar
http://www.youtube.com/watch?v=7CXuZdbLA4M someone help me im about to light this car on fire
Old Feb 6, 2011 | 11:02 AM
BigLou55's Avatar
could be the other crank sensor
Old Feb 6, 2011 | 05:25 PM
captain jack's Avatar
can you check to see what codes it's throwin?
Old Feb 6, 2011 | 06:16 PM
aleem's Avatar
I have checked all ignition coils, sensors, fuel system, etc. I believe my timing chain has problems(broken guide, tensionizer). I have proper compression, proper fuel pressure, and proper voltage.
http://www.youtube.com/watch?v=JXZbOPEkJzU
p1335
and o2sensors
Old Feb 6, 2011 | 06:20 PM
BigLou55's Avatar
your killing your starter in the mean time
Old Feb 6, 2011 | 07:34 PM
aleem's Avatar
The wires started to melt. Lifetime guarantee lol
Old Feb 7, 2011 | 07:11 AM
foodmanry's Avatar
Da Roller Coaster!
If you still have the same codes change out the sensor again. Perhaps you got a bad sensor? Did you put in an OEM sensor, or one from autozone/pep boys?
Old Feb 7, 2011 | 08:31 AM
aleem's Avatar
I replaced the first crank sensor by pully. today im going to replace the one by tranny.
Old Feb 7, 2011 | 08:48 PM
josueboca's Avatar
2000 Nissan ???
Old Feb 8, 2011 | 07:21 AM
aleem's Avatar
UPDATE: Turn out its a timing belt/ guide issue. Timing is off. Ill post picts on removal
Old Feb 8, 2011 | 02:46 PM
BigLou55's Avatar
u mean chain not belt right...
Old Feb 8, 2011 | 03:04 PM
aleem's Avatar
yea lol. after this car is fixed its being solf the upgradin to infinity fx50
Old Feb 8, 2011 | 06:43 PM
NAVY00MAXIMA's Avatar
Another one bites the dust! I'll keep rebuilding mine
Old Feb 9, 2011 | 04:45 PM
Amave's Avatar
So the engine is toast?
The timing chain shouldn't have any problems unless the tensioner went belly up ...
but thats usually a case of lack of oil changes or sludge.
since our tensioners are hydraulic
Old Feb 9, 2011 | 05:30 PM
BigLou55's Avatar
you gone part it out possibly?
Old Feb 9, 2011 | 07:00 PM
foodmanry's Avatar
Da Roller Coaster!
Bummer..what was root cause of the timing chain issue? Tensions toast, or lack of oil?
Old Feb 9, 2011 | 07:02 PM
aleem's Avatar
Since I bought my car It has been taken car off meaning oil changes+ a lil lucus, i removed that butter fly thing in the manifold. I drive it like it was supposed to be driven hard. its like this drive hard pay hard. my tensione and a guide broke im making a lil tutorial i post pics as soon as i can
Old Feb 9, 2011 | 07:03 PM
aleem's Avatar
after car is fixed gonna trade it with some cash for fx50
Old Feb 10, 2011 | 04:29 PM
foodmanry's Avatar
Da Roller Coaster!
Ouch...well it happens. I doubt your "hard driving" had much to do with it. It will just eventually wear and break.
Did you notice any engine chatter when you started up at all prior to having major problems? This is usually a sign with an issue going on with the timing chain.
Old Feb 10, 2011 | 07:18 PM
aleem's Avatar
Yes I did here some chatter about a month before. It got louder in time. I knew it was timing chain rattle. My friend had the same rattle on his 72 datsun
CRizz
41
Jun 7, 2021 05:42 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
02PearlSE
Oct 7, 2015 02:12 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
