NJ ORION HCCA car audio system for sale
I have pretty much an entire ORION system for sale minus a head unit. Everything with the exception of the capacitor is in NEW condition with literally 3 hrs of use. I would like to get $500 for everything listed below since i have no use. I had everything professionally installed
1) ORION HCCA 12IN SUB WITH THE SUBZONE ENCLOSURE which is specifically made for these subs. These are true SPL subs which can easily put out 1200 watts.
2) ORION HCCA 250G5
* Power output: 50x2@4ohms
* Power output: 100x2@2ohms
* Power output: 200x2@1ohm
* Power output: 400x2@.5ohm
* Power output: 200x1@4ohms
* Power output: 400x1@2ohms
* Power output: 800x1@1ohm
* Signal Processing: built-in equalization network@45Hz, continuously variable HP, LP, or BP crossover from 10Hz to 10kHz, INTELLiQ subwoofer optimizer, remote gain capability, left and right phase/gain controls, selectable aux rca output
* Fuse size: (2) 30 ATC
* 18" x 10.25" x 2.25" (457mm x 260mm x 57mm)
3) ORION 4 awg amp wiring kit - power, neg, RCA jacks and remote wire
4) ORION remote BASS GAIN wire - allows you to increase the BASS on the AMP right from the driver seat
5) ORION 1 FARAD CAPACITOR
6) AMP RACK - located behind the rear seats
specifically for the 5th and 5.5 gen
Every thing is in NEW working condition with 3 hrs of use with the exception of the 1 farad capacitor as i bought it used.
I will send pics upon request through email.
Thank you
2) ORION HCCA 250G5
Thank you
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Slamrod
Aug 10, 2015 12:33 PM
