Washer reservoir replacement question
Old May 2, 2011 | 05:52 PM
Laevateinn's Avatar
My 93 SE AT has a leaking washer reservoir. I'm looking for a replacement but I'm not sure what other years' reservoir is compatible with a 93 SE. And how will I replace the tank? Can I remove it from underneath the car?
Old May 3, 2011 | 12:09 AM
maximo018's Avatar
Yeah you can use one from 89 to 94 and I think you have to remove the front bumper. Or the splash guard.
Old May 3, 2011 | 01:04 AM
jonmandude's Avatar
Remove the splash guard. The fill tube pulls out the top with a simple quarter turn. Everything else comes out from underneath
Old May 3, 2011 | 01:21 AM
Laevateinn's Avatar
Thanks a lot guys. I'll try this later in the morning
Old May 3, 2011 | 01:51 AM
VQ'rInWLA's Avatar
Instead of sourcing another one, why not just use epoxy putty to seal up the holes? I recently patched up my homies reservoir on his 1st gen I30. Pulled it all the way out to find three dime sized holes and a few cracks. Sealed it up and alls well! $6 for a tube of putty.
Old May 3, 2011 | 09:27 AM
Laevateinn's Avatar
That's what I thought too. I'm thinking of applying permatex plastic repair kit that can withstand heat, dirt, and lots of vibration.
Old May 3, 2011 | 09:30 AM
VQ'rInWLA's Avatar
Go for it! Itll be a cheaper solution than replacing it.
Old May 3, 2011 | 12:09 PM
jbbons25's Avatar
Are you sure the washer reservoir is cracked? Maybe it's as simple as replacing the worn out rubber bushing on the washer motor.
Old May 3, 2011 | 12:15 PM
Maxkiller's Avatar
Where did you buy this car!???
rbuswell
Nov 17, 2016 04:54 AM
Justinmc760
Aug 23, 2015 03:10 AM
scarletsosa
Aug 17, 2015 09:09 PM
jchronis2552
Aug 13, 2015 07:48 AM
classymax420
Aug 6, 2015 06:35 PM
