Low beam works but not high beam?
Old May 6, 2011 | 10:09 AM
X-fimpg's Avatar
Hi
I recently purchased a 2001 Maxima and have no high beam on the right side.
So I replaced the lightbulb with a Sylvania 9003/HB2 but the high beam still doesn't work.
Am I missing something?
Old May 6, 2011 | 10:31 AM
Lochnivar's Avatar
Is this by chance a Canadian car?
And, if so, do the daytime running lights work?
X-fimpg's Avatar
And if so do the daytime running lights work?
Yes it is a Canadian car and the daytime lights do work...
Old May 6, 2011 | 10:33 AM
jowo9's Avatar
If you have a model with DRLs, then it's your DRL module that got fried. Since the highbeam circuit runs through there, it affects the right highbeam. That happened to mine (twice), so I just completely rewired my highbeams to a separate relay/switch.
jowo9's Avatar
Hmm... that's really odd, because both my DRLs stopped working when I had this problem.
Old May 6, 2011 | 10:41 AM
Lochnivar's Avatar
You could also try switching the L/R headlight relays...
This thread covers the DRL issue (which you aren't having) and does have some other info too.
http://forums.maxima.org/5th-generat...-your-drl.html
Old May 6, 2011 | 10:52 AM
X-fimpg's Avatar
Thanks everyone for your feedback, it allowed me to make sure I had checked the basics. I'm not terribly technical so i'll bring it into the shop and see what they say.
Old May 9, 2011 | 05:37 PM
X-fimpg's Avatar
The verdict is in: the DRL module was defective.
So $400 Canadian later and all is working again.
Thanks again for all your help!
Old May 22, 2011 | 06:57 PM
Kirinji's Avatar
Ok, so let me jump in on this thread since it's rather recent...
I have 2001 20th AE, and this evening while I was driving, I noticed that the passenger side's low beam is out. I switched back and forth b/w low and high beams, and the high on this light still works just fine, it's just the low-beat that decided to die.
Is there a remedy for this as well? I don't have the DRL thing in my car. Is it just the bulb that's out, (which I kinda doubt) or something more serious?
Any help would be appreciated. Thank you.
Old May 22, 2011 | 08:42 PM
DennisMik's Avatar
It could very well be the headlight bulb.
The headlight switch could also do it, but that is less likely.
Old May 23, 2011 | 05:10 AM
Kirinji's Avatar
Ok, thanks for the comment. I'll try switching it out and see what happens.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
kenc15
Aug 5, 2015 08:29 AM
