Drivin' on 3 lugs
Wow, I heard a kinda grinding sound on the way home the other day, a bit of an oscillation and worse when at a constant speed of slowing down. I got home and found two lugnuts missing, and a third one loose! eeeeeeeeekkkkkkk... Guess we forgot to tighten them up after the last race...
So, do I have to go to a dealer to get matching lugnuts, or will an auto parts store have them? I can't remember if everyone uses the same style and size or not...
Feel sorry for your max. Its missing some nuts. Hehe.. Yep, you can pick up lugnuts at the autoparts store. I know the pepboys that I sometimes go to has them. BUT, they didn't have my size when I went. They were out of stock. The key to my wheel locks broke. So I had the wheel locks taken off and I was driving around with 4 lugs on each wheel for a while. But yeah, the pepboys usually carried the lugnut. But they were just out the day I went.
ZuM
ZuM
Buy some factory wheel locks from courtesyparts.com
then you'll have two extra lug nuts once you put the locks on.
Down at maxus 2k pioneer saw that I was missing a lug nut...so I tighted the other 4 and luckily made it back to NY with no troubles and used one of the four extra lug nuts I had that came with my rims. Now I keep two extra in the car just in case that happenes again. If I loose two more I have my factory nuts that I use on my winter rims
I would get wheel locks to replace instead of replacement lugs just in case this happens....
https://maxima.org/forums/showthread...?threadid=5693
