FL 99' E39 528i 5 Speed Sport Wagon
Old May 22, 2011 | 06:20 AM
Xpcgamer's Avatar
Well the time has come for me to move on. I have spent a ton of money on this car and have receipts for it all. It needs a few things to be perfect but he cranks every time and the motor runs like a sewing machine. I am the 2nd owner. If you look at the following list closely you can see that all the high dollar maintenance items where already taken care like the rear subframe bushings and a new OEM ABS module. It has a dent on the left rocker panel from the previous owner and a dent on the right dog leg from an old lady who backed into me at a Publix. The car has it fair share of dings and rock chips and it has spent most of its life cruising the highway. Here is a list of things done and when. The car now has 133k and got it with 114k 2 1/2 years ago. Once I sell this I will be purchasing a 5.5 gen. I would'nt mind trading for 5.5 gen 6 speed. I can cash on my end if needed. Was looking for car with Leather-Gray or Black leather.
I'll start with the motor...
New OEM ABS Module
OEM Water Pump
Belts
OEM Tensioners and Pulleys
Intake Manifold Gaskets and Vacuum hoses
OEM CCV
Oil Filter housing gasket
Injector O rings
New Alternator
Fan Clutch(sachs)1/16/2011@129k
Fan shroud
Air Cleaner
Cabin Filters
Replaced ICV
DME has Active Auto Werkes Tune
Coolant Flush
Fuel Filter
Vanos Seals 1/16/2011@129K
Spark Plugs 1/16/2011@129K
VC Gasket 1/16/2011@129k
High Pressure Vanos line 1/16/2011@129k
New Vanos Banjo bolts and crush washers 1/16/2011@129k
New MAF Sensor 3/2/2011
New Duralast Battery 4/14/2011
Drive Train...
Cross Drilled and Slotted Rotors
Ceramic Pads
Stop Tech Stainless Lines
New *** front bearings
Fresh fluids
New DOT 3
Removed CDV
Refinished the RD Sport C4's myself. 18x9 and 18x9.5 3 piece rims.
Should be redone.
245/40 and 275/35 tires have 3K miles on them
545i shifter and bushings
ZHP ****
Body...
M5 bumper
Front Splitters
Blacked out kidneys
New Windshield washer pump
New Roundels
Front grill with working brake cooling ducts
Hella Face lift Headlights with 6K Halo bulbs
I have installed new Aluminum adjusters so no worries there.
OEM Hella Ballast and Bulbs
Celis Amber Tails No errors
DTM Electric mirrors-I have the Stock mirrors also.
Suspension...
Complete front End rebuild
All OEM
OEM Control Arms with Meyle HD bushings
OEM Tie rods
OEM Tie rod Boots
Bilstein Sport shocks
Racing Dynamics front springs(last ones sold and made)
Rear adjustable lowering links
New Rear Sub Frame Bushings
Interior...
New Ignition switch OEM
Pioneer HU DVD and Nav-Every thing is there is you want factory as it came with it from the factory.
Fosgate amp and Sub.
New steering wheel recover with perforated leather on the sides!
New Alcantara Tri Stitched Shift boot and E brake boot
The car needs both rear regulators
I have the Regulators
Airbag light is on. It is due to a Bad Airbag module. I have another module just needs to be installed and coded.
Rear washer pump
Drivers Seat is clicking
Drivers Seat leather is worn out and leaning(common problem with E39's)
Center Support Bearing will need to be replaced.
I have the CSB-Guibo and Tranny Mounts. All are OEM parts. Not da cheap stuff.
Headliner drooping a bit on the Sunroof panel.
Bumps and Bruises from the parking lots
Car has Factory Nav,HIDs, Comfort seats,Rear shades and Sport package and sliding loading floor. Very Desirable options and car.
HID Fogs with 35 watt Ballast and 3K bulbs-No errors on OBC.
Pics
Price is 6900.
Car is in Pembroke pInes Fl.
Kbn434 at Gmail dot com
Old May 22, 2011 | 04:49 PM
phatboislim's Avatar
id consider trading my 5th gen for this
Old May 24, 2011 | 05:24 AM
Xpcgamer's Avatar
Here are some interior shots. I was trying to get the condition of the seats in these. If anybody has or wants any specific shots let me know. I am going under the knife tomorrow but I can still check emails.
Thanks!
Headliner drooping on sunroff panel in this shot.
The passenger side door panel is broken or ripped. It was like this when I bought the car. Not sure what
happened.
Old May 24, 2011 | 07:05 PM
Xpcgamer's Avatar
Deposit received today. I will update on Monday.
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
