PAC SWI-PS wiring on 2003 Maxima with Pioneer AVIC-D3
Old Jul 27, 2011 | 11:23 AM
Stason's Avatar
Hey guys!
Just received the final part of my stereo install and have a question.
In the paper that came with the SWI-PS it says:
Code:
- Connect 150ohm resistor to Blue/Yellow wire
- Connect 47ohm resistor to Green/Black or Red wire
- Connect free ends or resistors to the interfaces White wire
- Connect Brown/White to ground
HOWEVER, on the PAC website the info is a little different (link):
Code:
- Connect a  150 ohm resistor to pin 27 (blue/yellow)
- Connect the free ends of the resistors to the INTERFACE'S White wire
- Connect pin pin 26 (green/black or red) in the vehicle connector to  INTERFACE'S White wire
- Connect pin 29 (brown/white) in the vehicle  connector to Ground
As you see, on the website it does NOT say to add a 47ohm resistor to pin26. Can someone please confirm if the 47ohm resistor is needed?
Thanks.
Old Jul 29, 2011 | 08:35 AM
Stason's Avatar
Thank you so much for many useful responses and ideas! LOL
I went ahead and put that 47ohm resistor in there (pin 26) along with 150ohm resistor (pin 27), everything seems to work fine. Programming of SWI-PS is NOT tricky at all as some say - just re-read the instructions a couple of times if you do not understand them, it is very straight-forward!
Tee-hee!
Old Aug 9, 2011 | 05:34 AM
02whitemaximase's Avatar
thanks for being the guinea pig, I will keep this in mind for my install. Hopefully it works for the long run.
Old Aug 23, 2011 | 09:07 AM
mendon99's Avatar
tastey wheat
the website will always be the most updated, it probably would've worked either way. pretty sure they stopped making the PS and now its the PAC-RC which does all radios...
MikesChevelle
Nov 23, 2024 11:17 AM
wingsfan24
Aug 15, 2015 07:35 PM
09maxshawn11
Aug 9, 2015 01:13 PM
papo99
Audio/Video/Electronics
Aug 9, 2015 12:55 PM
bassmann
Aug 3, 2015 07:53 PM
