One headlight goes dark; High Beam Ind comes on ???
on a 99' SE...
Having a problem where one headlight will go out. When it does, the high beam indicator (on dash) lights up. No amount of switching the switch seems to fix eithe rproblem, but within a few minutes it typically corrects itself - headlight comes back on, high beam indicator goes out.
Is there a relay that typically goes bad in these? Or the switch? I could use some pointers to common ailments.
Thanks,
Thanks,
take a look at the harness ill be willing to bet the ground contact on the bulb socket is a little burnt and now so is the headlight contact(s). if so you may need to replace the socket, i cut mine and soldered in a new one.
Exactly what happened to mine, I soldered in a new connector and all is well.
Finally got out there last week to repair it...
Turns out the connector was seriously degraded. One pole of the connector was corroded and/or burned. I imagine it corroded first, then the resistance caused it to start burning off. I replaced the connector and it's back in proper operation.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
