only one speaker working...Non bose, 03 se.
Old Aug 22, 2011 | 06:28 PM
xumengpeter's Avatar
Hi everyone, I just bought this car last week...Its a 03 SE without bose system. And I found out that the only speaker working properly is the front driver side one... no matter I`m listening to the radio or the cassette adapter for my mp3..didnt try cd coz I dont have one.. If I set the balance to R+5(all to the right), I can hear some sound from the right speaker, but only a little sound..
everything is original...anybody and give me a clue? Dont know where to put my hands on...
posted in the audio area..but no clues still...so put up one here to see if I can find something helpful?~
Thanks in advance!
Old Aug 22, 2011 | 06:49 PM
michael454rs's Avatar
blown speakers most likely
Old Aug 22, 2011 | 06:54 PM
TRAE_5GEN's Avatar
replace all of them. i had the same problem. i had one working the rest was blown
Old Aug 22, 2011 | 07:39 PM
replace all the speakers? what should I get... dont want to put too much money on it.. are they plug and play?
Old Aug 22, 2011 | 07:45 PM
any tips when buying them?
just want to keep the original look of the car...
Old Aug 22, 2011 | 10:05 PM
DennisMik's Avatar
Go to a place that sells car speakers and they will probably have a demonstration "wall" where you can listen to different brands of speakers. Hopefully you can find something that sounds good at a price you can afford. If you find something you like, note the make and model and see what you can buy them for on line.
Speakers are plug and play, but will have to do some work to get to them. The front speakers require you to remove the trim panel on the front door to get to it.
Old Aug 23, 2011 | 01:46 AM
036mtmax's Avatar
My driver door speaker stopped working the other day so i picked up a set of boston acoustic 6 1/2'' speakers and even with the factory head unit it sounds pretty incredible..I think the set ran me just over a hundred bucks.
Old Aug 23, 2011 | 11:34 AM
door panel removal is not a big deal...but the factory speakers use special connectors.. do the after market speakers use the same connectors or I need to solder some wires?? and I see from some threads said that I need to destroy the factory speakers to reuse the ring? difficult to do or not?
Old Aug 23, 2011 | 02:48 PM
DennisMik's Avatar
Most replacement speakers will not plug onto the factory harness, so you will have to improvise.
When you say "I need to destroy the factory speakers to reuse the ring", I am not sure of what you are talking about. When I replaced my speakers, I removed the old one and put the new one in. But if you had to destroy the old speaker, so what? It's bad anyway.
Old Aug 23, 2011 | 03:52 PM
how to deal with the wires?
and does the watts of the new speakers matter? I see there are like 250W... Am I able to use that? I need to change all four speakers.
Old Aug 23, 2011 | 05:20 PM
Froggmann's Avatar
Contact Crutchfield. And give one of their sales people a call. They should be able to recommend a decent set of factory replacements that will come with directions and the required harnesses to plug and play.
Old Aug 23, 2011 | 09:40 PM
alright..thanks
Old Aug 25, 2011 | 11:50 AM
djfrestyl's Avatar
Suspension Yoda
Aftermarket speakers will include wires and connectors. Just tap those wires into the existing OEM wires. Don't cut the harness off, in case you ever want to return to factory.
As for mounting, get these:
http://www.ebay.com/itm/Infiniti-G35...item5198c83005
Old Aug 25, 2011 | 12:08 PM
036mtmax's Avatar
I used an air saw to cut out the factory speaker out of the basket and then mounted the speakers to that, and then bolted them back into the door.Turned out nice but was a pita to cut the speaker out to allow the new speaker to fit flush.
Old Aug 25, 2011 | 12:29 PM
djfrestyl's Avatar
Suspension Yoda
Plus it doesn't allow for the speakers to be reused if/when converting back to stock.
Old Aug 25, 2011 | 07:24 PM
already ordered some speaker wire connectors from ebay...should be plug and play... but I`m concerning how can I get the factory speaker out of the mount and put the new speaker in?
Old Aug 25, 2011 | 07:36 PM
nelledge's Avatar
"I'm just sayin'..."
Short and sweet: If you can't figure out how to mount them once you have them out, listen to the experienced words of djfrestyl. It's a drastic understatement to say he knows what he's talking about when it comes to speaker installs. I'll quote his previous post for the sake of reassuring you.
Old Aug 25, 2011 | 07:58 PM
thanks
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
