Rear Brake Caliper rattle
Old Aug 24, 2011 | 05:17 PM
jr schultz's Avatar
Going over bumps I'm hearing a rattle sound coming from the back. When I brake going over the same bumps the sound goes away. I checked the rear calipers, and all the right parts are there. It doesn't seem that anything is missing...shims and what not. The bolts are as tight as I can get them both on the caliper brackets and the caliper to the pins. But, the calipers have some play in them where they are bolted to the pins. They can move a little by hand. I recently about 3 months ago had re-manufactured calipers put on by a Dodge tech I know. I trust his work. Any idea what could now make this rattle sound back there? With everything being tight I don't feel its a safety thing, but it is annoying.
Old Aug 25, 2011 | 02:50 PM
00MaxMayne's Avatar
It may just be your exhaust bouncing around. Check that out.
Old Aug 25, 2011 | 03:50 PM
jr schultz's Avatar
The exhaust wouldn't quiet down when the brakes are applied over bumps. Plus, when I was taking off the passenger side rear wheel I could hear the sound when I gave the wheel a hit with my foot to release it from the hub.
Old Aug 25, 2011 | 05:07 PM
Nelsito65's Avatar
I don't know if non-lubed pins would cause that kind of noise, but perhaps the pins were not re-lubed when they put the caliper back together. Another thing I can think of are the pad retaining clips; they tend to secure the pads when the piston is not pushing them against the disc.
Old Aug 26, 2011 | 09:52 PM
jency9488's Avatar
I have the same problem and the noise started after i changed my 4 rotors and brake pads. Its so F**king annoying. if any1 knows the solutions lmk asap and thanks.
Old Aug 27, 2011 | 01:40 PM
jr schultz's Avatar
Here's an update. I took the passenger side rear caliper off to inspect everything. Everything was there. Nothing was broke. All the bolts were tight. So, I lubed everything up that wasn't touching the rotor with high temp brake grease. Pins, around the pad retaining clips, back side of pads, and back side of shims for good measure. Put everything back together and took it for a drive over a bumpy road. The rattle sound is gone. I'm glad it wasn't an expensive fix, but I have a funny feeling I'll be doing this re-lube job again in a few months. Time will tell if the rattle stays away.
Old Aug 27, 2011 | 04:23 PM
Nelsito65's Avatar
Good to know the rattle is gone. On the back of the pads I thought we were supposed to apply something like that blue gluey stuff that comes in small packets (can't remember name now), so they stick to the piston and the opposite side of the caliper. I'm not sure if high temperature grease would have the same long time effect.
Old Aug 27, 2011 | 04:41 PM
nelledge's Avatar
"I'm just sayin'..."
I believe that
Originally Posted by Nelsito65
... blue gluey stuff that comes in small packets...
you're talking about is a high-temperature, synthetic grease(often called brake lube/grease).
Old Aug 27, 2011 | 04:46 PM
Nelsito65's Avatar
Originally Posted by nelledge
I believe that you're talking about is a high-temperature, synthetic grease(often called brake lube/grease).
I don't think you can "lube" pins with that sticky stuff. The stuff I'm talking about is called "Disc Brake Quiet" by Permatex.
Old Aug 27, 2011 | 05:10 PM
nelledge's Avatar
Oh, got it. You're using that stuff. The stuff I use works for lube as well as having anti-squeal and corrosion resistant properties. It's also Permatex brand. I believe it's called Ultra Disc Brake Synthetic Lube. Something like that. I'd go out to the garage to confirm, but it's still over 100°F outside and I'm feeling lazy.
Old Aug 27, 2011 | 08:55 PM
jr schultz's Avatar
I'm not sure the brand I used. I had to get some oil and a filter at the parts store today, so I just grabbed 2 packets of brake grease that came in a silver package. Whatever I used it worked. I'll keep you all posted as to whether the rattle sound stays gone for good.
Old Jul 10, 2015 | 02:02 PM
TheMafia's Avatar
Resurrection time....pictures below
as i had my car safetied we looked for the source of the rattle, definitively brakes. the bolts are on tight, but the caliper still sits loose on the bolt unless brake pressure is applied.
How do i dampen this sound without replacing the caliper?
Is this the same rattle you guys fixed with lube?
bolt is tight, but bushing or something is loose unless braking pressure is applied
rattle comes from this part being loose on the bolt that holds it, even when bolt is correctly torqued
Old Jul 12, 2015 | 05:58 AM
losifanatic's Avatar
I had to replace the caliper mount. The part the bolts go into. Mine apparently warn and when I replaced my calipers I got the banging sound over bumps. New bolts and the mount and all is good now.
Old Jul 13, 2015 | 06:48 AM
TheMafia's Avatar
ah, just the mount itself? thats better than the whole caliper itself!
to confirm this is the part you replaced: http://www.cardone.com/Products/Prod...=141536&p=rock ?
Also...
this part: http://www.rockauto.com/catalog/more...nid=511&jpid=2
would that remove the rattle? or does that not affect it?
Is this involved: http://www.rockauto.com/catalog/more...nid=513&jpid=0 ?
Old Jul 13, 2015 | 10:09 AM
Number 4 and number 1
Number 4 and number 1 is what was needed but for the rear
Old Jul 13, 2015 | 10:57 AM
TheMafia's Avatar
very nice response!!
so what did you find was actually loose? which one was worn, 4 or 1?
Old Jul 13, 2015 | 11:02 AM
Number 4 was worn but bought bolts just to have it all new
Old Jul 13, 2015 | 11:20 AM
TheMafia's Avatar
They say the above part is rear, but in the manual there is threading, what did yours look like?:
threading shown here
Old Jul 13, 2015 | 11:48 AM
Those are the right bolts. They just slide in.
Old Jul 21, 2015 | 07:19 AM
TheMafia's Avatar
all the parts are in for my rear brakes, job will be started this weekend
rbuswell
Nov 17, 2016 04:54 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
