Why does my seat move forward and back even when tightened down?
I figured this would be a common problem but didn't find anything in search. It might just be a worn out seat and there's nothing to be done, but I wanted to see if anyone had some ideas.
I've noticed that my driver's seat will kind of lurch forward 1/2" if I brake hard, and then will settle again. I don't notice anything under acceleration, but that's probably because my car is too slow
It's not that the seat moves forward on the tracks, the frame is locked to the floor and my power seat adjustments don't go out of whack.
No matter how many times I take the seat out and re-tighten the bolts, it always moves back and forth a bit. Are there any nuts inside the seat/frame that could be tightened?
It's not that the seat moves forward on the tracks, the frame is locked to the floor and my power seat adjustments don't go out of whack.No matter how many times I take the seat out and re-tighten the bolts, it always moves back and forth a bit. Are there any nuts inside the seat/frame that could be tightened?
mine did it too, turned out to be the gear on the motor not stayin put on the motor shaft, so after some crafty cuttin and weldin...its ok, but i dont recommend the way i did it, i would call nissan for ***** and giggles to see what they say
My 97 SE doesn't do it, but my 96 I30 does do this under hard braking. Almost feels like my *** is gonna slide right out of the seat when I brake. I'll have to take my seat apart and see for myself what could be causing it. I also have a tear on the leather so now would be a good time to fix both issues.
It is something with the gears underneath the seat. My second 4th gen has this problem and also my mother's 06 pathfinder did but it is still under extended warranty. We mentioned it to them and they had to replace the entire rail assembly under the seat...smh
scutmud
Aug 16, 2018 10:56 AM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
mines filthy...Irene was not nice to my clean car
