Replacing 95-96 steering wheel/airbag with 97-99
What all is needed? Just the wheel and airbag, or do I need the clock spring also.
Is the steering column the same for all 4th Gens?
Thanks.
Thanks.
the 95 & 96 use a slightly different steering column than the 97 to 99. Same for the steering wheel.
If you are replacing just the steering wheel itself, that's all you would need. You can swap the airbag and clock spring, assuming they are good.
They are different, ive got a 95 gle, and i swapped to a 97 se wheel. The wheel, spring and bag are different, and even the air bag harness and control under the arm rest, also. The only way i could see to do a complete swap and have everything working is it swap both bags, harness and srs module. goodluck
Thanks.
Well i tried to do the complete swap, but the harness is toatally different. I ended up just swapping steering wheel and air bag. You will also have to relocate you cruise control under dash, as it connects to the clockspring. All my hardware is in place just no harness to connect it all.
Maxima_Joe
Nov 25, 2015 08:19 AM
Mrbizness1
Aug 18, 2015 08:43 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
