weird power lock issue
This started recently....I'll press the unlock button once, it unlocks the drivers side (working as it should). I press unlock again and it unlocks the rest of the doors and then relocks all of them including the driver's side. I'll unlock with the key and the doors all re-lock. it takes like 2-3 times of unlocking to get them to stay unlocked.
Any idea on why? It's just annoying....
It will be the one that's not unlocking. You should be able to tell by the lock position which one it is. You might be able to manually unlock/lock it to get it working again if it's just sticking.
I think you guys are getting confused as to what I described...everything unlocks when i push it twice but it just re-locks instantaneously. How do I go about figuring out which power lock is "stuck" if thats the case?
GGENIUS, learn how to read next time before you start with the derogatory attitude.
One of the doors (prolly passenger side) isnt fully locking. U prolly need to adjust the locking rod in the door.
Also, check anti-theft relay and all factory alarm equipment the may not have been removed.
I'm not sure if its just the 99s that does this but I've had this same issue a couple times, don't know how to fix it but I just unlocked them all then started the car then tried locking and unlockin with the door panel then shut the car off. Got out and tried locking and unlocking again. I do know for me the problem came from when I go to unlock the doors someone pulls on the handle before it fully unlocks but I hope this helps
I have seen my 99 behave like this when someone pulled on a door handle at the same time that I was unlocking the car with the remote. fixed by manually unlocking the offending door from inside (pulling the lock lever out), then unlocking again with the remote to get it back in sync.
u need to remove the door trim. then remove the plastic bag weather guard. The locking rod connects the door handle lock to the locking mechanism. U can loosen a bolt that secures the rod and then move the rod up and down in the "slot" for the bolt u jus removed. The more u adjust the more flush the door handle lock should become.
If I didn't do that, (because the door lock **** was sitting just between lock and unlock), any slight movement's would cause the **** the move slightly and cause all the doors to lock again and engage the alarm.
If the door lock solenoid is in fact the problem, you should be able to find a replacement part without too much trouble if search around.
One more thought: On some cars, if the key is left in the ignition and you try to lock the doors using the key fob or door switch, the locks lock, then immediately unlock again. It's a safety feature to keep you from locking your keys in the car. Don't know if the Max does that, and mine isn't at home to test, but if it does have that feature the sensor that detects the key in the ignition could be the issue.
lowpost99
Oct 26, 2025 06:53 PM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
