engine coolant temp sensor
Old Nov 8, 2011 | 11:12 AM
joseph.mcgowen's Avatar
my 96 is throwing p0115 and p0125 but cant find it anywhere i got one at autozone but it was to big and the others are discontinued where can i get it and what size is it?and also stumped on the closed loop circuit malfunction (fuel system) if anyone can help with that
Old Nov 8, 2011 | 01:03 PM
augnon's Avatar
I bought mine at auto 7 months ago worked fine. Try pep boys advanced auto napa or oreily or just order from rockauto.com
Old Nov 8, 2011 | 07:32 PM
wxm's Avatar
wxm
Just get one from Nissan. It is not very expensive (< $25 IIRC ).
Old Nov 9, 2011 | 09:15 AM
asand1's Avatar
There is a sender and a sensor next to each other. tha smaller one with a single spade terminal is for the gauge. the other one may be larger and has two (i think) terminals. the second is the ECT sensor that you need to replace.
Old Nov 10, 2011 | 10:20 AM
i kno there are 2 next to each other and its the biger one but when i went to get they asked if it wAs 7/32 or 1/8 and there was another size i can't remember i jus don't know which it is
Old Feb 19, 2013 | 01:39 PM
lambo43085's Avatar
OK this may be a little off subject but I'm stumped I have a 95 maxima that all of a sudden just died on me. I was driving to store and on my way back home it started driving poorly lost power would only hit 25 MPH then eventually died and would crank but not fire. After getting it home by towing I ran diagnostic on it came back with
1005 egr solenoid
0303 upstream o2 sensor (left bank)
0407 crankshaft position sensor
0503 upstream o2 sensor (right bank)
0308 closed loop control fault
0606 cylinder no. 3 misfire
So I've replaced crank sensor, coil pack on cylinder no.3, new battery, all new plugs, prior to all that i also did this maintanance. PCvvalve, fuel filter& water pump. Didn't mess with egr system since that has nothing to do with ignition. But one of my friends said my catalyst system could have collapsed causing it to not fire. Also if this is a factor it was cold when car stopped running. Please any and all information will greatly appreciated
Old Feb 19, 2013 | 02:30 PM
ShocknAwe's Avatar
1005 egr solenoid
I would start your own thread for more answers. Did you use a Nissan Coil pack? What plugs did you get?
Old Feb 19, 2013 | 02:57 PM
njmaxseltd's Avatar
Did you replace the correct crankshaft sensor, there's 2 of them.
CPS REF - Located just about the crank pulley
CPS POS - Located on the transmission bell housing, looks at the flywheel.
Old Feb 19, 2013 | 03:51 PM
lambo43085's Avatar
Yeah it was the (ref) one. My next option would be camshaft pos sensor.
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
