engine coolant temp sensor
my 96 is throwing p0115 and p0125 but cant find it anywhere i got one at autozone but it was to big and the others are discontinued where can i get it and what size is it?and also stumped on the closed loop circuit malfunction (fuel system) if anyone can help with that
I bought mine at auto 7 months ago worked fine. Try pep boys advanced auto napa or oreily or just order from rockauto.com
There is a sender and a sensor next to each other. tha smaller one with a single spade terminal is for the gauge. the other one may be larger and has two (i think) terminals. the second is the ECT sensor that you need to replace.
OK this may be a little off subject but I'm stumped I have a 95 maxima that all of a sudden just died on me. I was driving to store and on my way back home it started driving poorly lost power would only hit 25 MPH then eventually died and would crank but not fire. After getting it home by towing I ran diagnostic on it came back with
1005 egr solenoid
0303 upstream o2 sensor (left bank)
0407 crankshaft position sensor
0503 upstream o2 sensor (right bank)
0308 closed loop control fault
0606 cylinder no. 3 misfire
So I've replaced crank sensor, coil pack on cylinder no.3, new battery, all new plugs, prior to all that i also did this maintanance. PCvvalve, fuel filter& water pump. Didn't mess with egr system since that has nothing to do with ignition. But one of my friends said my catalyst system could have collapsed causing it to not fire. Also if this is a factor it was cold when car stopped running. Please any and all information will greatly appreciated
1005 egr solenoid
1005 egr solenoid
1005 egr solenoid
MR2 T'd
07-09-2021 05:06 AM
