Whats this hose?
Whats this hose?
Anyone know what this hose is for? It dies not seal on its connection due to being burnt. Can this cause any problems? It goes under the intake manifold passenger side. Can not figure out how to load pictures so I hope link works
http://s1095.photobucket.com/albums/...Picture026.jpg
http://s1095.photobucket.com/albums/...Picture027.jpg
That is part of the crankcase ventilation system. It connects the 2 valve cover chambers so that the one PCV valve can do both sides of the engine. I had to replace my hose when I did valve cover gaskets because my hose was so brittle that it cracked when I took it off.
I advise you get a new hose ASAP
If I'm not mistaken, it's a vacuum hose that bridges from the front valve cover to the rear valve cover.
If it's cracked or if it's not holding a seal I'd get a hose and replace it. I replaced mine with a generic aftermarket hose.
HerpDerp1919
Sep 29, 2015 02:02 PM
you guys replied while I was sitting here typing then watching tv and by the time I hit the reply button you had your answer already OP.
